Combined tracking and vibrotactile rendering with a wearable armband - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2020
We introduce a wearable armband interface capable of tracking its orientation in space as well as providing vibrotactile sensations. It is composed of four vibrotactile motors , able to provide contact sensations, an inertial measurement unit (IMU), and a battery-powered Arduino board. We use two of these armbands, worn on the forearm and the upper arm, to interact in an immersive Virtual Reality (VR) environment. The system renders in VR the movements of the user's arm as well as its interactions with virtual objects. Specifically, users are asked to catch a series of baseballs using their armbands-equipped arm. Whenever one baseball hits the arm, the armband closer to the contact vibrates. The amplitude of the vibration is proportional to the distance between the impact point and the position of the activated armband.
Aggravi-HAPTICS-demo.pdf (148.37 Ko) Télécharger le fichier
Aggravi-HAPTICS-demo.mp4 (3.36 Mo) Télécharger le fichier
hal-02479084 , version 1 (14-02-2020)
  • HAL Id : hal-02479084 , version 1
Marco Aggravi, Tommaso Lisini Baldi, Claudio Pacchierotti, Domenico Prattichizzo. Combined tracking and vibrotactile rendering with a wearable armband. Hands- on demostration at IEEE Haptics Symposium (HAPTICS), Mar 2020, Washington, United States. 2020. ⟨hal-02479084⟩
136 Consultations
175 Téléchargements
