Lyapunov characterization of uniform exponential stability for nonlinear infinite-dimensional systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2022
In this paper we deal with infinite-dimensional nonlinear forward complete dynamical systems which are subject to external disturbances. We first extend the well-known Datko lemma to the framework of the considered class of systems. Thanks to this generalization, we provide characterizations of the uniform (with respect to disturbances) local, semi-global, and global exponential stability, through the existence of coercive and non-coercive Lyapunov functionals. The importance of the obtained results is underlined through some applications concerning 1) exponential stability of nonlinear retarded systems with piecewise constant delays, 2) exponential stability preservation under sampling for semilinear control switching systems, and 3) the link between input-to-state stability and exponential stability of semilinear switching systems.
HCMS-preprint-hal-130220.pdf (267.42 Ko) Télécharger le fichier
hal-02479777 , version 1 (14-02-2020)
Ihab Haidar, Yacine Chitour, Paolo Mason, Mario Sigalotti. Lyapunov characterization of uniform exponential stability for nonlinear infinite-dimensional systems. IEEE Transactions on Automatic Control, 2022, 67 (4), pp.1685-1697. ⟨10.1109/TAC.2021.3080526⟩. ⟨hal-02479777⟩
284 Consultations
471 Téléchargements
