Bivariate spline spaces and minimal determining sets, Journal of Computational and Applied Mathematics, vol.119, issue.12, p.1327, 2000. ,
RAGS: Rational geometric splines for surfaces of arbitrary topology, Computer Aided Geometric Design, vol.31, issue.2, p.97110, 2014. ,
Flexible G 1 interpolation of quad meshes, Graphical Models, vol.76, issue.6, p.669681, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01064552
Smooth Bézier Surfaces over Unstructured Quadrilateral Meshes. Lecture Notes of the Unione Matematica Italiana, 2017. ,
G 1 -smooth splines on quad meshes with 4-split macro-patch elements, Computer Aided Geometric Design, vol.52, p.106125, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01491676
Isogeometric analysis with strong multipatch C 1 -coupling, Computer Aided Geometric Design, vol.62, p.294310, 2018. ,
Recursively generated B-spline surfaces on arbitrary topological meshes, Computer-Aided Design, vol.10, issue.6, p.350355, 1978. ,
Interpolating G 1 Bézier surfaces over irregular curve networks for ship hull design, Computer-Aided Design, vol.38, issue.6, p.641660, 2006. ,
Analysis-suitable G 1 multi-patch parametrizations for C 1 isogeometric spaces, Computer Aided Geometric Design, vol.47, p.93113, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01404076
On smooth bicubic surfaces from quad meshes, International Symposium on Visual Computing, p.8796, 2008. ,
Manifold splines, Graphical Models, vol.68, issue.3, p.237254, 2006. ,
Matched Gk-constructions always yield Ck-continuous isogeometric elements, Computer Aided Geometric Design, vol.34, p.6772, 2015. ,
Variational design and fairing of spline surfaces, Comput. Graph. Forum, vol.13, p.143154, 1994. ,
Bicubic G 1 interpolation of irregular quad meshes using a 4-split, International Conference on Geometric Modeling and Processing, p.409422, 2006. ,
Isogeometric analysis with geometrically continuous functions on planar multi-patch geometries, Computer Methods in Applied Mechanics and Engineering, vol.316, p.209234, 2017. ,
Dimension and basis construction for analysis-suitable G 1 two-patch parameterizations, Computer Aided Geometric Design, p.7589, 2017. ,
An isogeometric C 1 subspace on unstructured multi-patch planar domains, Computer Aided Geometric Design, vol.69, p.5575, 2019. ,
Isogeometric analysis with geometrically continuous functions on two-patch geometries, Computers & Mathematics with Applications, vol.70, issue.7, p.15181538, 2015. ,
Generalizing bicubic splines for modeling and IGA with irregular layout, Computer-Aided Design, vol.70, p.2335, 2016. ,
Improved shape for renable surfaces with singularly parameterized irregularities, Computer-Aided Design, vol.90, 2017. ,
Renable G 1 functions on G 1 free-form surfaces, Computer Aided Geometric Design, vol.54, p.6173, 2017. ,
Renable bi-quartics for design and analysis, Computer-Aided Design, vol.102, p.204214, 2018. ,
A G 1 triangular spline surface of arbitrary topological type, Computer Aided Geometric Design, vol.11, issue.3, p.303330, 1994. ,
Smooth spline surfaces over irregular meshes, Proceedings of the 21st Annual Conference on Computer Graphics and Interactive Techniques, p.303310, 1994. ,
, Spline Functions on Triangulations, 2007.
Isogeometric analysis using manifold-based smooth basis functions, Computer Methods in Applied Mechanics and Engineering, vol.316, p.547567, 2017. ,
Dimension and bases for geometrically continuous splines on surfaces of arbitrary topology, Computer Aided Geometric Design, vol.45, p.108133, 2016. ,
Jörg Peters. Geometric continuity. Handbook of computer aided geometric design, Constructive Approximation, vol.7, p.193229, 1991. ,
On the complexity of smooth spline surfaces from quad meshes, Computer Aided Geometric Design, vol.27, issue.1, p.96105, 2010. ,
Ulrich Reif. Biquadratic G-spline surfaces, Computer Aided Geometric Design, vol.14, issue.3, p.193205, 1995. ,
G 1 interpolation of generally unrestricted cubic Bézier curves, Computer Aided Geometric Design, vol.4, issue.1-2, p.2339, 1987. ,
Errata: G 1 interpolation of generally unrestricted cubic Bézier curves, Computer Aided Geometric Design, vol.6, issue.2, p.167171, 1989. ,
Scaolding skeletons using spherical Voronoï diagrams, 50, 2017. LAGOS'17 -IX Latin and American Algorithms, Graphs and Optimization, vol.62, p.45 ,
High-order approximation of implicit surfaces by triangular spline surfaces, Computer-Aided Design, vol.41, issue.6, p.441455, 2009. ,
Smooth cubic spline spaces on unstructured quadrilateral meshes with particular emphasis on extraordinary points: Geometric design and isogeometric analysis considerations, Computer Methods in Applied Mechanics and Engineering, vol.327, p.411458, 2017. ,
Manifold-based surfaces with boundaries, Computer Aided Geometric Design, vol.28, issue.1, p.122, 2011. ,
Construction of Manifolds via Compatible Sparse Representations, ACM Transactions on Graphics, vol.35, issue.2, p.110, 2016. ,
André Galligo, and Boniface Nkonga. H 1 -parametrizations of complex planar physical domains in isogeometric analysis, Computer Methods in Applied Mechanics and Engineering, vol.318, p.296318, 2017. ,
Fitting B-spline Curves to Point Clouds by Curvature-based Squared Distance Minimization, ACM Trans. Graph, vol.25, issue.2, p.214238, 2006. ,
A simple manifold-based construction of surfaces of arbitrary smoothness, SIGGRAPH '04, p.271275, 2004. ,
Foundations of Algebraic Geometry, 1946. ,
