Ideal Interpolation, H-Bases and Symmetry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Multivariate Lagrange and Hermite interpolation are examples of ideal interpolation. More generally an ideal interpolation problem is defined by a set of linear forms, on the polynomial ring, whose kernels intersect into an ideal. For an ideal interpolation problem with symmetry, we address the simultaneous computation of a symmetry adapted basis of the least interpolation space and the symmetry adapted H-basis of the ideal. Beside its manifest presence in the output, symmetry is exploited computationally at all stages of the algorithm.
ideal_interpolation.pdf (712.08 Ko) Télécharger le fichier
hal-02482098 , version 1 (17-02-2020)
hal-02482098 , version 2 (07-07-2020)
Erick Rodriguez Bazan, Evelyne Hubert. Ideal Interpolation, H-Bases and Symmetry. ISSAC 2020 - International Symposium on Symbolic and Algebraic Computation, Jul 2020, Kalamata, Greece. ⟨10.1145/3373207.3404057⟩. ⟨hal-02482098v2⟩
224 Consultations
249 Téléchargements
