Vertex Approximate Gradient Discretization preserving positivity for two-phase Darcy flows in heterogeneous porous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2020
Konstantin Brenner
  • Fonction : Auteur
  • PersonId : 1062104
Roland Masson
El Houssaine Quenjel
  • Fonction : Auteur
  • PersonId : 1064730
In this article, a new nodal discretization is proposed for two-phase Darcy flows in heterogeneous porous media. The scheme combines the Vertex Approximate Gradient (VAG) scheme for the approximation of the gradient fluxes with an Hybrid Upwind (HU) approximation of the mobility terms in the saturation equation. The discretization in space incorporates naturally nodal interface degrees of freedom (d.o.f.) allowing to capture the transmission conditions at the interface between different rock types for general capillary pressure curves. It is shown to guarantee the physical bounds for the saturation unknowns as well as a nonnegative lower bound on the capillary energy flux term. Numerical experiments on several test cases exhibit that the scheme is more robust compared with previous approaches allowing the simulation of 3D large Discrete Fracture Matrix (DFM) models.
Positive-Vag-Diphasique.pdf (4.42 Mo) Télécharger le fichier
hal-02483161 , version 1 (18-02-2020)
Konstantin Brenner, Roland Masson, El Houssaine Quenjel. Vertex Approximate Gradient Discretization preserving positivity for two-phase Darcy flows in heterogeneous porous media. Journal of Computational Physics, 2020, ⟨10.1016/j.jcp.2020.109357⟩. ⟨hal-02483161⟩
131 Consultations
113 Téléchargements
