The transitive reduction of a directed graph, SIAM Journal on Computing, vol.1, issue.2, pp.131-137, 1972. ,
Using bayesian networks for root cause analysis in statistical process control, Expert Systems with Applications, vol.38, issue.9, pp.11230-11243, 2011. ,
Stability and scalability in decision trees, Computational Statistics, vol.18, issue.3, pp.505-520, 2003. ,
Log analysis via space-time pattern matching, 14th International Conference on Network and Service Management (CNSM), pp.303-307, 2018. ,
Hidden anomaly detection in telecommunication networks, 2012 8th international conference on network and service management (cnsm) and 2012 workshop on systems virtualiztion management (svm), pp.82-90, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00702587
Failure diagnosis using decision trees, International Conference on Autonomic Computing, pp.36-43, 2004. ,
Pattern matching of alarm flood sequences by a modified smith-waterman algorithm, chemical engineering research and design, vol.91, issue.6, pp.1085-1094, 2013. ,
Introduction to Algorithms, 2009. ,
, Stationary Time-Series Models, 2004.
Pattern matching in historical data, AIChE journal, vol.48, issue.9, pp.2022-2038, 2002. ,
Minimisation of acyclic deterministic automata in linear time, Theoretical Computer Science, vol.92, issue.1, pp.181-189, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-00619678
Identification of common molecular subsequences, Journal of molecular biology, vol.147, issue.1, pp.195-197, 1981. ,
, Survey on models and techniques for root-cause analysis, 2017.
Application of artificial neural networks in process fault diagnosis, Automatica, vol.29, issue.4, pp.843-849, 1993. ,
High-performance pattern-matching for intrusion detection, Proceedings IEEE INFOCOM 2006. 25TH IEEE International Conference on Computer Communications, pp.1-13, 2006. ,
Applications of object-oriented bayesian networks for condition monitoring, root cause analysis and decision support on operation of complex continuous processes, Computers & chemical engineering, vol.29, issue.9, pp.1996-2009, 2005. ,
A deep neural network for unsupervised anomaly detection and diagnosis in multivariate time series data, Proceedings of the AAAI Conference on Artificial Intelligence, vol.33, pp.1409-1416, 2019. ,
