, Optimum Array Processing, 2002.
Exact maximum likelihood parameter estimation of superimposed exponential signals in noise, IEEE Transactions Acoustics Speech Signal Processing, vol.34, issue.5, pp.1081-1089, 1986. ,
Estimation of spectral parameters of correlated signals in wavefields, Signal Processing, vol.11, issue.4, pp.329-337, 1986. ,
Accuracy of maximum-likelihood estimates for array processing, Proceesings ICASSP, vol.12, 1987. ,
Maximum likelihood direction finding of stochastic sources: a separable solution, Proceedings ICASSP, vol.5, pp.2893-2896, 1988. ,
Multiple Emitter Location and Signal Parameter Estimation, IEEE Transactions Antennas Propagation, vol.34, issue.3, pp.276-280, 1986. ,
Multiple source DF signal processing: An experimental system, IEEE Transactions Antennas Propagation, vol.34, issue.3, pp.281-290, 1986. ,
ESPRIT-Estimation of Signal Parameters via Rotational Invariance Techniques, IEEE Transactions Acoustics Speech Signal Processing, vol.37, issue.7, pp.984-995, 1989. ,
Novel eigenanalysis method for direction estimation, Proceedings IEE-Radar Sonar Navigation, vol.137, pp.19-26, 1990. ,
, IEEE Transactions Acoustics Speech Signal Processing, vol.37, issue.5, pp.720-741, 1989.
Performance study of conditional and unconditional Direction of Arrival Estimation, IEEE Transactions Acoustics Speech Signal Processing, vol.38, issue.10, pp.1793-1795, 1990. ,
, Further Results and Comparisons, vol.38, pp.2140-2150, 1990.
The statistical performance of the MUSIC and the minimum-norm algorithms in resolving plane waves in noise, IEEE Transactions Acoustics Speech Signal Processing, vol.34, issue.2, pp.331-341, 1986. ,
Bias analysis of the MUSIC location estimator, IEEE Transactions Signal Processing, vol.40, issue.10, pp.2559-2569, 1992. ,
Modified Subspace Algorithms for DoA Estimation with Large Arrays, IEEE Transactions Signal Processing, vol.56, issue.2, pp.598-614, 2008. ,
MUSIC and maximum likelihood performance breakdown, IEEE Transactions Signal Processing, vol.56, issue.8, pp.3944-3958, 2008. ,
Improved Estimation of Eigenvalues and Eigenvectors of Covariance Matrices Using Their Sample Estimates, IEEE Transactions Information Theory, vol.54, issue.11, pp.5113-5129, 2008. ,
