Y. Choi, D. Kim, Y. Oh, and B. J. You, Posture/walking control for humanoid robot based on kinematic resolution of com jacobian with embedded motion, IEEE Transactions on Robotics, vol.23, issue.6, pp.1285-1293, 2007.
H. Diedam, D. Dimitrov, P. B. Wieber, K. Mombaur, and M. Diehl, Online walking gait generation with adaptive foot positioning through linear model predictive control, IEEE/RSJ Int. Conference on Intelligent Robots and Systems, pp.1121-1126, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00390566
J. Englsberger and C. Ott, Walking stabilization for humanoid robots based on control of the capture point, 2012.
J. Englsberger, C. Ott, M. A. Roa, A. Albu-schäffer, and G. Hirzinger, Bipedal walking control based on capture point dynamics, IEEE/RSJ Int. Conference on Intelligent Robots and Systems, 2011.
URL : https://hal.archives-ouvertes.fr/hal-02487644
H. Ferreau, H. Bock, and M. Diehl, An online active set strategy to overcome the limitations of explicit mpc, International Journal of Robust and Nonlinear Control, vol.18, issue.8, pp.816-830, 2008.
A. L. Hof, The 'extrapolated center of mass' concept suggests a simple control of balance in walking, Human Movement Science, vol.27, pp.112-125, 2008.
S. Kajita, F. Kanehiro, K. Kaneko, K. Yokoi, and H. Hirukawa, The 3d linear inverted pendulum mode: A simple modeling for a biped walking pattern generation, IEEE Int. Conf. on Robotics and Automation, pp.239-246, 2001.
S. Kajita, F. Kanehiro, K. Kaneko, K. Fujiwara, K. Harada et al., Biped walking pattern generation by using preview control of zero-moment point, IEEE Int. Conf. on Robotics and Automation, pp.1620-1626, 2003.
D. Mayne, J. Rawlings, C. V. Rao, and P. O. Scokaert, Constrained model predictive control: Stability and optimality, Automatica, vol.36, pp.789-814, 2000.
T. Mcgeer, Passive dynamic walking, The International Journal of Robotics Research, vol.9, issue.2, pp.62-82, 1990.
C. Ott, C. Baumgärtner, J. Mayr, M. Fuchs, R. Burger et al., Development of a biped robot with torque controlled joints, IEEE-RAS Int. Conf. on Humanoid Robots, pp.167-173, 2010.
J. Pratt, J. Carff, S. Drakunov, and A. Goswami, Capture point: A step toward humanoid push recovery, IEEE-RAS Int. Conf. on Humanoid Robots, pp.200-207, 2006.
J. Roy and L. L. Whitcomb, Adaptive force control of position/velocity controlled robots: Theory and experiment, IEEE Transactions on Robotics and Automation, vol.18, issue.2, pp.121-137, 2002.
J. J. Slotine and W. Li, Applied Nonlinear Control, 1991.
B. Stephens, Push Recovery Control for Force-Controlled Humanoid Robots, 2011.
T. Sugihara, Y. Nakamura, and H. Inoue, Realtime humanoid motion generation through zmp manipulation based on inverted pendulum control, IEEE Int. Conf. on Robotics and Automation, pp.1404-1409, 2002.
W. Suleiman, E. Yoshida, F. Kanehiro, J. P. Laumond, and A. Monin, On human motion imitation by humanoid robot, ICRA, pp.2697-2704, 2008.
URL : https://hal.archives-ouvertes.fr/hal-00166838
T. Takenaka, T. Matsumoto, Y. , and T. , Real time motion generation and control for biped robot -1st report: Walking gait pattern generation, IEEE/RSJ Int. Conference on Intelligent Robots and Systems, pp.1084-1091, 2009.
M. Vukobratovic and Y. Stepanenko, On the stability of anthropomorphic systems, Mathematical Biosciences, vol.15, pp.1-37, 1972.
P. B. Wieber, Trajectory free linear model predictive control for stable walking in the presence of strong perturbations, IEEE-RAS Int. Conf. on Humanoid Robots, 2006.
URL : https://hal.archives-ouvertes.fr/inria-00390462
