Control of a Silicone soft tripod robot via uncertainty compensation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2020
Soft robot is an emergent research field which has variant promising applications, and the control of such robots is still challenging. Unlike using different techniques (such as Beam theory, Cosserat theory or high dimensional finite-element method) to model the dynamics of soft robots, this paper introduces a simplified nominal model with uncertainty to describe its dynamic behavior. The link between this simple model and the finite-element method has been established, and a robust controller is proposed, by compensating the uncertainty which is estimated in a finite time by applying different types of estimators. The experiments have been made for different scenarios, and the corresponding results show the efficiency of the proposed method.
RALH.pdf (1.31 Mo) Télécharger le fichier
hal-02487883 , version 1 (21-02-2020)
Gang Zheng. Control of a Silicone soft tripod robot via uncertainty compensation. IEEE Robotics and Automation Letters, 2020, 5 (2), pp.2801 - 2807. ⟨10.1109/LRA.2020.2974714⟩. ⟨hal-02487883⟩
168 Consultations
382 Téléchargements
