Multiobjective optimization in bioinformatics and computational biology, IEEE/ACM Trans Comput Biol Bioinforma, vol.4, issue.2, pp.279-292, 2007. ,
Metabolic engineering with multi-objective optimization of kinetic models, J Biotechnol, vol.222, pp.1-8, 2016. ,
Multi-objective optimization of enzyme manipulations in metabolic networks considering resilience effects, BMC Syst Biol, vol.5, issue.1, p.145, 2011. ,
Multi-objective optimization of genome-scale metabolic models: the case of ethanol production, Ann Oper Res, vol.276, issue.1, pp.211-227, 2019. ,
Optknock: a bilevel programming framework for identifying gene knockout strategies for microbial strain optimization, Biotechnol Bioeng, vol.84, issue.6, pp.647-57, 2003. ,
Bilevel optimization techniques in computational strain design, Comput Chem Eng, vol.72, pp.363-72, 2015. ,
Predicting metabolic engineering knockout strategies for chemical production: accounting for competing pathways, Bioinformatics, vol.26, issue.4, pp.536-579, 2009. ,
OptPipe -a pipeline for optimizing metabolic engineering targets, BMC Syst Biol, vol.11, issue.1, p.143, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01672905
In silico constraint-based strain optimization methods: the quest for optimal cell factories, Microbiol Mol Biol Rev, vol.80, issue.1, pp.45-67, 2016. ,
Computing complex metabolic intervention strategies using constrained minimal cut sets, Metab Eng, vol.13, issue.2, pp.204-213, 2011. ,
Evaluating evolutionary multiobjective algorithms for the in silico optimization of mutant strains, 8th IEEE International Conference on BioInformatics and BioEngineering, 2008. ,
Robust design of microbial strains, Bioinformatics, vol.28, issue.23, pp.3097-104, 2012. ,
Technological trends, global market, and challenges of bio-ethanol production, Biotechnol Adv, vol.28, issue.6, pp.817-830, 2010. ,
Model based optimization of biochemical systems using multiple objectives: a comparison of several solution strategies, Math Comput Model Dyn Syst, vol.12, issue.5, pp.469-87, 2006. ,
Multicriteria optimization of biochemical systems by linear programming: application to production of ethanol by Saccharomyces cerevisiae, Biotechnol Bioeng, vol.83, issue.3, pp.335-378, 2003. ,
The Escherichia coli MG1655 in silico metabolic genotype: its definition, characteristics, and capabilities, Proc Nat Acad Sci, vol.97, issue.10, pp.5528-5561, 2000. ,
Metabolic flux balance analysis and the in silico analysis of Escherichia coli K-12 gene deletions, BMC Bioinforma, vol.1, issue.1, p.1, 2000. ,
What is flux balance analysis, Nat Biotechnol, vol.28, issue.3, pp.245-253, 2010. ,
Flux-balance analysis of mitochondrial energy metabolism: consequences of systemic stoichiometric constraints, Am J Physiol Regul Integr Comp Physiol, vol.280, issue.3, pp.695-704, 2001. ,
Flux balance analysis of biological systems: applications and challenges, Brief Bioinforma, vol.10, issue.4, pp.435-449, 2009. ,
Metabolic Flux Balancing: Basic Concepts, Scientific and Practical Use, Bio/technology, vol.12, issue.10, pp.994-1002, 1994. ,
Stoichiometric flux balance models quantitatively predict growth and metabolic by-product secretion in wild-type Escherichia coli W3110, Appl Environ Microbiol, vol.60, issue.10, pp.3724-3755, 1994. ,
Creation and analysis of biochemical constraint-based models: the COBRA Toolbox v3 ,
Analysis of optimality in natural and perturbed metabolic networks, Proc Nat Acad Sci, vol.99, issue.23, pp.15112-15119, 2002. ,
SCIP: solving constraint integer programs, Math Program Comput, vol.1, issue.1, pp.1-41, 2009. ,
, Mathematical Software -ICMS 2016, 5th International Conference, vol.9725, pp.259-264, 2016.
Increased expression of the yeast multidrug resistance ABC transporter Pdr18 leads to increased ethanol tolerance and ethanol production in high gravity alcoholic fermentation, Microb Cell Fact, vol.11, p.98, 2012. ,
Yeast 5 -an expanded reconstruction of the Saccharomyces cerevisiae metabolic network, BMC Syst Biol, vol.6, issue.1, p.55, 2012. ,
Progress in metabolic engineering of Saccharomyces cerevisiae, Microbiol Mol Biol Rev, vol.72, issue.3, pp.379-412, 2008. ,
Metabolic engineering strategies for optimizing acetate reduction, ethanol yield and osmotolerance in Saccharomyces cerevisiae, Biotechnol Biofuels, vol.10, issue.1, p.107, 2017. ,
In silico aided metabolic engineering of Saccharomyces cerevisiae for improved bioethanol production, Metab Eng, vol.8, issue.2, pp.102-111, 2006. ,
Evolutionary programming as a platform for in silico metabolic engineering, BMC bioinforma, vol.6, issue.1, p.308, 2005. ,
Regulatory on/off minimization of metabolic flux changes after genetic perturbations, Proc Nat Acad Sci, vol.102, issue.21, pp.7695-7700, 2005. ,
, Springer Nature remains neutral with regard to jurisdictional claims in published maps and institutional affiliations
