Jumping Evaluation of Nested Regular Path Queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Joachim Niehren
Sylvain Salvati
Nested regular path queries are used for querying graph databases and RDF triple stores. We pro- pose a new algorithm for evaluating nested regular path queries on a graph from a set of start nodes in combined linear time. We show that this complexity upper bound can be reduced by making it de- pendent on the size of the query’s top-down needed subgraph, a notion that we introduce. For many queries in practice, the top-down needed subgraph is way smaller than the whole graph. Our algo- rithm is based on a novel compilation schema from nested regular path queries to monadic datalog queries. Its complexity upper bound follows from known properties of top-down datalog evaluation. As an application, we show that our algorithm permits to reformulate in simple terms a variant of a very efficient automata-based algorithm proposed by Maneth and Nguyen that evaluates navigational path queries in datatrees based on indexes and jumping. Moreover, it overcomes some limitations of Maneth and Nguyen’s: it is not bound to trees and applies to graphs; it is not limited to forward navigational XPath but can treat any nested regular path query and it can be implemented efficiently without any dedicated techniques, by using any efficient top-down datalog evaluator. We confirm the efficiency of our algorithm experimentally based on an implementation with LogicBlox.
2.pdf (343.32 Ko) Télécharger le fichier
hal-02492780 , version 1 (27-02-2020)
hal-02492780 , version 2 (10-06-2020)
hal-02492780 , version 3 (16-03-2022)
hal-02492780 , version 4 (15-05-2022)
hal-02492780 , version 5 (16-05-2022)
hal-02492780 , version 6 (04-08-2022)
  • HAL Id : hal-02492780 , version 6
Joachim Niehren, Sylvain Salvati, Rustam Azimov. Jumping Evaluation of Nested Regular Path Queries. ICPL 2022 - 38th International Conference on Logic Programming, Jul 2022, Haifa, Israel. ⟨hal-02492780v6⟩
309 Consultations
217 Téléchargements
