A two-dimensional method for a family of dispersive shallow water model, Encycl. Metropolitana, vol.5, pp.291-369, 1845. ,
A fast and stable wellbalanced scheme with hydrostatic reconstruction for Shallow Water flows, SIAM J. Sci. Comput, vol.25, issue.6, pp.2050-2065, 2004. ,
Kinetic entropy inequality and hydrostatic reconstruction scheme for the Saint-Venant system, Math. Comp, vol.85, issue.302, pp.2815-2837, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01063577
Barré de Saint-Venant, Théorie du mouvement non permanent des eaux avec applications aux crues des rivières et à l'introduction des marées dans leur lit, Transport of pollutant in shallow water flows : A two time steps kinetic method, vol.206, pp.147-154, 1871. ,
Model equations for long waves in nonlinear dispersive systems, Philos. Trans. Royal Soc. London Series A, vol.272, pp.47-78, 1972. ,
Boussinesq equations and other systems for small-amplitude long waves in nonlinear dispersive media: Part I. Derivation and linear theory, J. Nonlinear Sci, vol.12, pp.283-318, 2002. ,
Nonlinear stability of finite volume methods for hyperbolic conservation laws and well-balanced schemes for sources, Birkhäuser, Differential and integral equations, vol.18, pp.891-934, 2004. ,
An energy-consistent depthaveraged Euler system: Derivation and properties, Discrete and Continuous Dynamical Systems -Series B, vol.20, issue.4, pp.961-988, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01011691
Long-time effects of bottom topography in shallow water, Nonlinear phenomena in ocean dynamics, vol.98, p.76005, 1995. ,
Numerical solution of the Navier-Stokes equations, Math. Comp, vol.22, p.3723, 1968. ,
Hyperbolic divergence cleaning for the MHD equations, J. Comp. Phys, vol.172, issue.2, pp.645-673, 2002. ,
A few remarks on ordinary differential equations, Comm. Part. Diff. Eq, vol.21, pp.11-12, 1996. ,
Ordinary differential equations, transport theory and Sobolev spaces, Invent. Math, vol.98, pp.511-547, 1989. ,
Wave propagation over uneven bottoms, Advanced Series on Ocean Engineering -World Scientific, 1997. ,
Rigorous justification of the Favrie-Gavrilyuk approximation to the Serre-Green-Naghdi model, Nonlinearity, vol.32, issue.10, pp.3772-3797, 2019. ,
An efficient hyperbolic relaxation system for dispersive non-hydrostatic water waves and its solution with high order discontinuous Galerkin schemes, filippini:breaking, vol.394, pp.381-417, 2016. ,
Derivation of Viscous Saint-Venant System for Laminar Shallow Water; Numerical Validation, Discrete Contin. Dyn. Syst. Ser. B, vol.1, issue.1, pp.89-102, 2001. ,
URL : https://hal.archives-ouvertes.fr/inria-00072549
Numerical approximation of hyperbolic systems of conservation laws, Applied Mathematical Sciences, vol.118, 1996. ,
A derivation of equations for wave propagation in water of variable depth, J. Fluid Mech, vol.78, pp.237-246, 1976. ,
Robust explicit relaxation technique for solving the Green-Naghdi equations, Finite volume methods for hyperbolic problems, vol.399, 2002. ,
, Sur les équations différentielles ordinaires et les équations de transport, vol.326, pp.833-838, 1998.
815-827. unesco [30] Unesco, Thermodynamic equation of seawater: Calculation and use of thermodynamic properties, Journal of Waterway, Port, Coastal and Ocean Engineering, vol.119, issue.6, pp.618-638, 1967. ,
