Transfer between long-term and short-term memory using Conceptors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2020
We introduce a recurrent neural network model of working memory combining short-term and long-term components. e short-term component is modelled using a gated reservoir model that is trained to hold a value from an input stream when a gate signal is on. e long-term component is modelled using conceptors in order to store inner temporal pa erns (that corresponds to values). We combine these two components to obtain a model where information can go from long-term memory to short-term memory and vice-versa and we show how standard operations on conceptors allow to combine long-term memories and describe their e ect on short-term memory.
draft_cog_comp-without-preambule.pdf (3.56 Mo) Télécharger le fichier
hal-02494493 , version 1 (10-03-2020)
hal-02494493 , version 2 (13-11-2020)
Anthony Strock, Nicolas P. Rougier, Xavier Hinaut. Transfer between long-term and short-term memory using Conceptors. 2020. ⟨hal-02494493v1⟩
239 Consultations
312 Téléchargements
