An Optimized Linear Model Predictive Control Solver - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
This article addresses the fast on-line solution of a sequence of quadratic programs underlying a linear model predictive control scheme. We introduce an algorithm which is tailored to efficiently handle small to medium sized problems with relatively small number of active constraints. Different aspects of the algorithm are examined and its computational complexity is presented. Finally, we discuss a modification of the presented algorithm that produces "good" approximate solutions faster.
LMPC_solver_bfg09_springer.pdf (135.71 Ko) Télécharger le fichier
hal-02495862 , version 1 (02-03-2020)
Dimitar Dimitrov, Pierre-Brice Wieber, Olivier Stasse, Hans Joachim Ferreau, Holger Diedam. An Optimized Linear Model Predictive Control Solver. Recent Advances in Optimization and its Applications in Engineering, Springer Berlin Heidelberg, pp.309-318, 2010, ⟨10.1007/978-3-642-12598-0_27⟩. ⟨hal-02495862⟩
67 Consultations
199 Téléchargements
