CFD-DEM Simulations of Current-Induced Dune Formation and Morphological Evolution, Advances in Water Resources, vol.06, pp.228-239, 2016. ,
Numerical simulation of sediment transport in open channel flow, vol.1, pp.507-514, 2012. ,
A Stochastic Model for Particulate Suspension Flow in Porous Media, vol.62, pp.23-53, 2006. ,
Modeling of Particle Filtration in a Porous Medium with Changing Flow Direction, Procedia Engineering, vol.153, pp.157-161, 2016. ,
CFD modeling for pipeline flow of fine particles at high concentration, International Journal of Multiphase Flow, vol.43, pp.85-100, 2012. ,
Direct numerical simulation of particulate flow via multigrid FEM techniques and the fictitious boundary method, International Journal for Numerical Methods in Fluids, vol.06, issue.5, pp.531-566, 2006. ,
Hydrodynamics of Suspensions of Passive and Active Rigid Particles: A Rigid Multiblob Approach, Communications in Applied Mathematics and Computational Science, vol.11, issue.2, pp.217-296, 2016. ,
Simulation of Fresh Concrete Flow, 2014. ,
An accurate method to include lubrication forces in numerical simulations of dense Stokesian suspensions, Journal of Fluid Mechanics, vol.769, pp.369-386, 2015. ,
Suspensions of prolate spheroids in Stokes flow. Part 1. Dynamics of a finite number of particles in an unbounded fluid, Journal of Fluid Mechanics, vol.251, pp.411-442, 1993. ,
Microscopic dynamics of flow in molecularly narrow pores, Journal of Chemical Physics, vol.93, issue.5, pp.3427-3431, 1990. ,
Stokesian dynamics, Annual Review of Fluid Mechanics, vol.01, pp.111-157, 1988. ,
The motion of suspended particles almost in contact, International Journal of Multiphase Flow, vol.1, pp.343-371, 1974. ,
Dynamic simulation of spheroid motion between two parallel plane walls in low-Reynolds-number Poiseuille flow, Journal of Fluid Mechanics, vol.553, pp.187-226, 2006. ,
Numerical study of the sedimentation of spheroidal particles, International Journal of Multiphase Flow, vol.12, pp.16-34, 2016. ,
Sedimentation of an ellipsoidal particle in narrow tubes, Physics of Fluids, vol.26, issue.5, p.53302, 2014. ,
Local lubrication model for spherical particles within incompressible Navier-Stokes flows, Physical Review E 03, vol.97, issue.3, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01896218
A penalization method to take into account obstacles in incompressible flows, Numerische Mathematik, vol.81, issue.4, pp.497-520, 1999. ,
A versatile sharp interface immersed boundary method for incompressible flows with complex boundaries, Journal of Computational Physics, vol.227, issue.10, pp.4825-4852, 2008. ,
Numerical solution of the Navier-Stokes equations, Mathematics of Computation, vol.22, pp.745-762, 1968. ,
Sur l'approximation de la solution des équations de Navier-Stokes par la méthode des pas fractionnaires II. Archive for Rational Mechanics and, Analysis, vol.32, pp.377-385, 1969. ,
Modelling and Simulations of Contacts in Particle-Laden Flows. Theses, 2018. ,
URL : https://hal.archives-ouvertes.fr/tel-01962216
Modelling the dynamics of a sphere approaching and bouncing on a wall in a viscous fluid, Journal of Fluid Mechanics, vol.747, pp.422-446, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00980559
An efficient interface capturing method for a large collection of interacting bodies immersed in a fluid, Journal of Computational Physics, vol.378, pp.143-177, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01236468
On the Distance Between Two Ellipsoids, SIAM Journal on Optimization, vol.13, issue.1, pp.298-308, 2002. ,
Collision model for fully-resolved simulations of flows laden with finite-size particles, Physical Review E, vol.10, issue.5, 2015. ,
, Low Reynolds Number Flow between Converging Spheres. Mathematika 05, vol.29, pp.58-66, 1982.
The slow motion of a sphere through a viscous fluid towards a plane surface, Institution of Chemical Engineering Symposium, vol.16, pp.242-251, 1961. ,
On the Slow Motion Generated in a Viscous Fluid by the Approach of a Sphere to a Plane Wall or Stationary Sphere, Mathematika, vol.16, issue.1, pp.37-49, 1969. ,
Drag reduction in turbulent channel flow laden with finite-size oblate spheroids, Journal of Fluid Mechanics, vol.01, pp.43-70, 2017. ,
Numerical modelling of finite-size particle collisions in a viscous fluid, Physics of Fluids, vol.25, p.83302, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01078260
Collision modelling for the interface-resolved simulation of spherical particles in viscous fluids, Journal of Fluid Mechanics, vol.209, pp.445-489, 2012. ,
Interface-resolved direct numerical simulations of the interactions between neutrally buoyant spheroidal particles and turbulent channel flows, Physics of Fluids, vol.30, issue.11, p.115103, 2018. ,
The motion of ellipsoidal particles immersed in a viscous fluid, Proceedings of the Royal Society of London A: Mathematical, Physical and Engineering Sciences, vol.01, issue.715, pp.161-179, 1922. ,
Sources of spurious force oscillations from an immersed boundary method for moving-body problems, Journal of Computational Physics, vol.230, pp.2677-2695, 2011. ,
