, European maritime safety agency -vessel tracking globally (lrit), 2019.
Recent Advances in Graph Partitioning, pp.117-158, 2016. ,
Optimal operator replication and placement for distributed stream processing systems. SIGMETRICS Perform, Eval. Rev, vol.44, issue.4 ,
Collaborative reuse of streaming dataflows in iot applications, 2017 IEEE 13th International Conference on e-Science (e-Science), pp.403-412, 2017. ,
A Linear-Time Heuristic for Improving Network Partitions, 19th Design Automation Conference, pp.175-181, 1982. ,
Distributed scheduling of event analytics across edge and cloud, ACM Trans. Cyber-Phys. Syst, vol.2, issue.4 ,
A Polynomial Algorithm for the k-Cut Problem for Fixed k, Mathematics of Operations Research, vol.19, issue.1, pp.24-37, 1994. ,
Streamcloud: An elastic and scalable data streaming system, IEEE Transactions on Parallel and Distributed Systems, vol.23, issue.12, pp.2351-2365, 2012. ,
URL : https://hal.archives-ouvertes.fr/lirmm-00748992
A multi-level algorithm for partitioning graphs, Supercomputing '95:Proceedings of the 1995 ACM/IEEE Conference on Supercomputing, pp.28-28, 1995. ,
A catalog of stream processing optimizations, ACM Computing Surveys (CSUR), vol.46, issue.4, p.46, 2014. ,
Opening the black boxes in data flow optimization, Proc. VLDB Endow, vol.5, issue.11, pp.1256-1267, 2012. ,
Graph partitioning and constructing optimal decision trees are polynomial complete problems ,
On knapsacks, partitions, and a new dynamic programming technique for trees, Mathematics of Operations Research, vol.8, issue.1, pp.1-14, 1983. ,
Multilevelk-way partitioning scheme for irregular graphs, Journal of Parallel and Distributed Computing, vol.48, issue.1, pp.96-129, 1998. ,
An efficient heuristic procedure for partitioning graphs, Bell System Technical Journal, vol.49, issue.2, pp.291-307, 1970. ,
A linear tree partitioning algorithm, SIAM Journal on Computing, vol.6, issue.1, pp.151-154, 1977. ,
Efficient Algorithm for the Partitioning of Trees, IBM Journal of Research and Development, vol.18, issue.3, pp.217-224, 1974. ,
Network-aware operator placement for stream-processing systems, 22nd International Conference on Data Engineering (ICDE'06), pp.49-49, 2006. ,
Planner: Cost-efficient Execution Plans Placement for Uniform Stream Analytics on Edge and Cloud, WORKS 2018: 13th Workflows in Support of Large-Scale Science Workshop, pp.1-10, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01892718
Synergy: Sharing-aware component composition for distributed stream processing systems, pp.322-341, 2006. ,
Auto-parallelizing stateful distributed streaming applications, Proceedings of the 21st international conference on Parallel architectures and compilation techniques, pp.53-64, 2012. ,
