A Spatio-Temporal Data Imputation Model for Supporting Analytics at the Edge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current applications developed for the Internet of Things (IoT) usually involve the processing of collected data for delivering analytics and support efficient decision making. The basis for any processing mechanism is data analysis, usually having as an outcome responses in various analytics queries defined by end users or applications. However, as already noted in the respective literature, data analysis cannot be efficient when missing values are present. The research community has already proposed various missing data imputation methods paying more attention of the statistical aspect of the problem. In this paper, we study the problem and propose a method that combines machine learning and a consensus scheme. We focus on the clustering of the IoT devices assuming they observe the same phenomenon and report the collected data to the edge infrastructure. Through a sliding window approach, we try to detect IoT nodes that report similar contextual values to edge nodes and base on them to deliver the replacement value for missing data. We provide the description of our model together with results retrieved by an extensive set of simulations on top of real data. Our aim is to reveal the potentials of the proposed scheme and place it in the respective literature.
I3E2019_paper_98.pdf (338.98 Ko) Télécharger le fichier
hal-02510089 , version 1 (17-03-2020)
Paternité
Christos Anagnostopoulos, Stathes Hadjiefthymiades, Kostas Kolomvatsos, Panagiota Papadopoulou. A Spatio-Temporal Data Imputation Model for Supporting Analytics at the Edge. 18th Conference on e-Business, e-Services and e-Society (I3E), Sep 2019, Trondheim, Norway. pp.138-150, ⟨10.1007/978-3-030-29374-1_12⟩. ⟨hal-02510089⟩
46 Consultations
56 Téléchargements
