Accuracy of MRI Classification Algorithms in a Tertiary Memory Center Clinical Routine Cohort - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Alzheimer's Disease Année : 2020
Aline Mendes
Jamila Ahdidan
  • Fonction : Auteur
Dalila Samri
  • Fonction : Auteur
  • PersonId : 920123
BACKGROUND: Automated volumetry software (AVS) has recently become widely available to neuroradiologists. MRI volumetry with AVS may support the diagnosis of dementias by identifying regional atrophy. Moreover, automatic classifiers using machine learning techniques have recently emerged as promising approaches to assist diagnosis. However, the performance of both AVS and automatic classifiers has been evaluated mostly in the artificial setting of research datasets. OBJECTIVE: Our aim was to evaluate the performance of two AVS and an automatic classifier in the clinical routine condition of a memory clinic. METHODS: We studied 239 patients with cognitive troubles from a single memory center cohort. Using clinical routine T1-weighted MRI, we evaluated the classification performance of: 1) univariate volumetry using two AVS (volBrain and Neuroreader™); 2) Support Vector Machine (SVM) automatic classifier, using either the AVS volumes (SVM-AVS), or whole gray matter (SVM-WGM); 3) reading by two neuroradiologists. The performance measure was the balanced diagnostic accuracy. The reference standard was consensus diagnosis by three neurologists using clinical, biological (cerebrospinal fluid) and imaging data and following international criteria. RESULTS: Univariate AVS volumetry provided only moderate accuracies (46% to 71% with hippocampal volume). The accuracy improved when using SVM-AVS classifier (52% to 85%), becoming close to that of SVM-WGM (52 to 90%). Visual classification by neuroradiologists ranged between SVM-AVS and SVM-WGM. CONCLUSION: In the routine practice of a memory clinic, the use of volumetric measures provided by AVS yields only moderate accuracy. Automatic classifiers can improve accuracy and could be a useful tool to assist diagnosis.
Morin_ClinAD_Classifier_JAD_final_version.pdf (561.36 Ko) Télécharger le fichier
hal-02511532 , version 1 (18-03-2020)
Alexandre Morin, Jorge Samper-González, Anne Bertrand, Sebastian Ströer, Didier Dormont, et al.. Accuracy of MRI Classification Algorithms in a Tertiary Memory Center Clinical Routine Cohort. Journal of Alzheimer's Disease, 2020, pp.1-10. ⟨10.3233/JAD-190594⟩. ⟨hal-02511532⟩
171 Consultations
283 Téléchargements
