A sparse matrix arithmetic based on hmatrices. part i: Introduction to h-matrices, Computing, vol.62, issue.2, pp.89-108, 1999. ,
Construction and arithmetics of hmatrices, Computing, vol.70, issue.4, pp.295-334, 2003. ,
, Hierarchical Matrices: Algorithms and Analysis, 2015.
Improving multifrontal methods by means of block lowrank representations, SIAM Journal on Scientific Computing, vol.37, issue.3, pp.1451-1474, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-00776859
Block Low-Rank multifrontal solvers: complexity, performance and scalability, 2017. ,
URL : https://hal.archives-ouvertes.fr/tel-01708791
Sparse supernodal solver using block low-rank compression: Design, performance and analysis, Journal of computational science, vol.27, pp.255-270, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01660665
Lattice h-matrices on distributed-memory systems, Proceedings of the International Parallel and Distributed Processing Symposium, pp.389-398, 2018. ,
Distributed-memory lattice h-matrix factorization, The International Journal of High Performance Computing Applications, vol.33, pp.1046-1063, 2019. ,
, Hmat-oss library github repository
Résolution directe rapide pour leséléments finis de frontière e? electromagnétisme et acoustique: H-Matrices, Parallélisme et applications industrielles.École doctorale Galilée, 2014. ,
Faster, cheaper, better a hybridization methodology to develop linear algebra software for gpus, CEA/DAM ; Total E&P ,
URL : https://hal.archives-ouvertes.fr/inria-00547847
Achieving high performance on supercomputers with a sequential task-based programming model, CEA/DAM ; Total E&P ,
URL : https://hal.archives-ouvertes.fr/hal-01618526
, The openmp api specification for parallel programming home page
Dynamic task discovery in parsec: A data-flow task-based runtime, Proceedings of the 8th Workshop on Latest Advances in Scalable Algorithms for Large-Scale Systems, pp.1-8, 2017. ,
, Starpu runtime system home page
Starpu: a unified platform for task scheduling on heterogeneous multicore architectures, Concurrency and Computation: Practice and Experience, vol.23, issue.2, pp.187-198, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00384363
Quark users guide, vol.268, 2011. ,
, Matrix Computations, 1996.
Adaptive cross approximation of dense matrices, Int. Association Boundary Element Methods Conf., IABEM, pp.28-30, 2002. ,
Randomized numerical linear algebra: Foundations & algorithms, 2020. ,
, LAPACK Users guide. SIAM, 1999.
Hierarchical matrix techniques on massively parallel computers, 2012. ,
H-lu factorization on many-core systems, Computing and Vis. in Science, vol.16, issue.3, pp.105-117, 2013. ,
Task-parallel lu factorization of hierarchical matrices using ompss, 2017 IEEE International Parallel and Distributed Processing Symposium Workshops (IPDPSW), pp.290-294, 2017. ,
Parallel hierarchical matrices with adaptive cross approximation on symmetric multiprocessing clusters, Journal of Information Processing, vol.22, issue.4, pp.642-650, 2014. ,
, H2lib library home page
Semiautomatic task graph construction for h-matrix arithmetic, 2019. ,
A hierarchical fast direct solver for distributed memory machines with manycore nodes, 2019. ,
URL : https://hal.archives-ouvertes.fr/cea-02304706
Exploiting nested task-parallelism in the h-lu factorization, Journal of Computational Science, vol.33, pp.20-33, 2019. ,
Improving the integration of task nesting and dependencies in openmp, 2017 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.809-818, 2017. ,
On the compression of low rank matrices, SIAM Journal on Scientific Computing, vol.26, issue.4, pp.1389-1404, 2005. ,
Fast direct solvers for elliptic partial differential equations, 2011. ,
A direct solver with o(n) complexity for integral equations on one-dimensional domains, Frontiers of Mathematics in China, vol.7, issue.2, pp.217-247, 2012. ,
Bridging the gap between flat and hierarchical low-rank matrix formats: the multilevel blr format, SIAM Journal on Scientific Computing, vol.41, issue.3, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01774642
, TEST FEMBEM library github repository
