On greedy randomized kaczmarz method for solving large sparse linear systems, SIAM J. Sci. Comput, vol.40, issue.1, pp.592-606, 2018. ,
On greedy randomized coordinate descent methods for solving large linear least-squares problems, Numer. Linear Algebr. Appl, vol.26, issue.4, pp.1-15, 2019. ,
Towards optimal multi-level checkpointing, IEEE Trans. Computers, vol.66, issue.7, pp.1212-1226, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01339788
Divisible load theory: a new paradigm for load scheduling in distributed systems, Cluster Computing, vol.6, issue.1, pp.7-17, 2003. ,
Thinking in sync: The bulksynchronous parallel approach to large-scale computing, ACM Computing reviews, vol.57, issue.6, pp.322-327, 2016. ,
Highly portable and efficient implementations of parallel adaptive n-body methods, Proc. ACM Supercomputing, pp.1-20, 1997. ,
Toward Exascale Resilience, Int. J. High Performance Computing Applications, vol.23, issue.4, pp.374-388, 2009. ,
Toward exascale resilience: 2014 update, Supercomputing frontiers and innovations, vol.1, issue.1, 2014. ,
A higher order estimate of the optimum checkpoint interval for restart dumps, Future Generation Comp. Syst, vol.22, issue.3, pp.303-312, 2006. ,
Optimization of multi-level checkpoint model for large scale HPC applications, IPDPS. IEEE, 2014. ,
Direct bulk-synchronous parallel algorithms, J. Parallel Distributed Computing, vol.22, issue.2, pp.251-267, 1994. ,
Randomized iterative methods for linear systems, SIAM Journal on Matrix Analysis and Applications, vol.36, issue.4, pp.1660-1690, 2015. ,
Checkpointing workflows for fail-stop errors, IEEE Trans. Computers, vol.67, issue.8, pp.1105-1120, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01701611
A Generic Approach to Scheduling and Checkpointing Workflows, Int. Journal of High Performance Computing Applications, vol.33, issue.6, pp.1255-1274, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02140295
A rapid hierarchical radiosity algorithm, Proceedings of the 18th annual conference on Computer graphics and interactive techniques, pp.197-206, 1991. ,
Fault-Tolerance Techniques for High-Performance Computing, Computer Communications and Networks, 2015. ,
BSPlib: The BSP programming library, Parallel Computing, vol.24, issue.14, pp.1947-1980, 1998. ,
Randomized methods for linear constraints: convergence rates and conditioning. Math. Operations Research, vol.35, pp.641-654, 2010. ,
Convergence properties of the randomized extended gauss-seidel and kaczmarz methods, SIAM Journal on Matrix Analysis and Applications, vol.36, issue.4, pp.1590-1604, 2015. ,
Design, modeling, and evaluation of a scalable multi-level checkpointing system, 2010. ,
, Code for ICPP double-blind review
The performance of parallel iterative solvers, Computers and Mathematics with Applications, vol.50, issue.7, pp.1179-1189, 2005. ,
Ten reasons to use divisible load theory, IEEE Computer, vol.36, issue.5, pp.63-68, 2003. ,
, Iterative Methods for Sparse Linear Systems. Society for Industrial and Applied Mathematics, 2003.
A randomized kaczmarz algorithm with exponential convergence, J. Fourier Analysis and Applications, vol.15, issue.2, p.262, 2009. ,
Top 500 Supercomputer Sites, 2018. ,
On the optimum checkpoint selection problem, SIAM J. Comput, vol.13, issue.3, 1984. ,
The complexity of enumeration and reliability problems, SIAM J. Comput, vol.8, issue.3, pp.410-421, 1979. ,
A first order approximation to the optimum checkpoint interval, Comm. of the ACM, vol.17, issue.9, pp.530-531, 1974. ,
