Scalable Fine-Grained Proofs for Formula Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Automated Reasoning Année : 2020
We present a framework for processing formulas in automatic theorem provers, with generation of detailed proofs. The main components are a generic contextual recursion algorithm and an extensible set of inference rules. Clausification, skolemization, theory-specific simplifications, and expansion of 'let' expressions are instances of this framework. With suitable data structures, proof generation adds only a linear-time overhead, and proofs can be checked in linear time. We implemented the approach in the SMT solver veriT. This allowed us to dramatically simplify the code base while increasing the number of problems for which detailed proofs can be produced, which is important for independent checking and reconstruction in proof assistants. To validate the framework, we implemented proof reconstruction in Isabelle/HOL.
processing_article.pdf (236.16 Ko) Télécharger le fichier
hal-02515103 , version 1 (23-03-2020)
Haniel Barbosa, Jasmin Blanchette, Mathias Fleury, Pascal Fontaine. Scalable Fine-Grained Proofs for Formula Processing. Journal of Automated Reasoning, 2020, 64 (3), pp.485-510. ⟨10.1007/s10817-018-09502-y⟩. ⟨hal-02515103⟩
82 Consultations
102 Téléchargements
