Experimental Comparison of Velocity Observers: A Scissored Pair Control Moment Gyroscope Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Access Année : 2020
We consider scissored pair gyroscopes as an auxiliary stabilization system for legged robots. A standard state-feedback control can stabilize the system if all states are available; thus, the velocity estimation becomes the key element for the stabilization. To this end, we implement and experimentally compare a model-free linear differentiator, a model-based full-state linear observer with time-varying gains, and a model-based homogeneous nonlinear differentiator. Moreover, we also show that the considered system cannot be partially linearized via a change of coordinates, and thus is not suitable for a recently reported class of nonlinear observers. The proposed designs are tested on an experimental scissored pair control moment gyroscope setup constructed for a walking robot stabilization.
08963889.pdf (1.32 Mo) Télécharger le fichier
hal-02516558 , version 1 (16-07-2020)
Stanislav Aranovskiy, Igor Ryadchikov, Evgeny Nikulchev, Jian Wang, Dmitry Sokolov. Experimental Comparison of Velocity Observers: A Scissored Pair Control Moment Gyroscope Case Study. IEEE Access, 2020, 8, pp.21694-21702. ⟨10.1109/ACCESS.2020.2968221⟩. ⟨hal-02516558⟩
208 Consultations
207 Téléchargements
