Reconciling Qualitative, Abstract, and Scalable Modeling of Biological Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nature Communications Année : 2020
Predicting biological systems’ behaviors requires taking into account many molecular and genetic elements for which limited information is available past a global knowledge of their pairwise interactions. Logical modeling, notably with Boolean Networks (BNs), is a well-established approach that enables reasoning on the qualitative dynamics of networks. Several dynamical interpretations of BNs have been proposed. The synchronous and (fully) asynchronous ones are the most prominent, where the value of either all or only one component can change at each step. Here we prove that, besides being costly to analyze, these usual interpretations can preclude the prediction of certain behaviors observed in quantitative systems. We introduce an execution paradigm, the Most Permissive Boolean Networks (MPBNs), which offers the formal guarantee not to miss any behavior achievable by a quantitative model following the same logic. Moreover, MPBNs significantly reduce the complexity of dynamical analysis, enabling to model genome-scale networks.
s41467-020-18112-5.pdf (587.9 Ko) Télécharger le fichier
hal-02518582 , version 1 (26-08-2020)
hal-02518582 , version 2 (23-09-2020)
Loïc Paulevé, Juraj Kolčák, Thomas Chatain, Stefan Haar. Reconciling Qualitative, Abstract, and Scalable Modeling of Biological Networks. Nature Communications, 2020, 11, ⟨10.1038/s41467-020-18112-5⟩. ⟨hal-02518582v2⟩
217 Consultations
95 Téléchargements
