An unfitted Hybrid High-Order method for the Stokes interface problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2021
We design and analyze a hybrid high-order (HHO) method on unfitted meshes to approximate the Stokes interface problem. The interface can cut through the mesh cells in a very general fashion. A cell-agglomeration procedure prevents the appearance of small cut cells. Our main results are inf-sup stability and a priori error estimates with optimal convergence rates in the energy norm. Numerical simulations corroborate these results.
cutHHO_Stokes.pdf (860.08 Ko) Télécharger le fichier
hal-02519896 , version 1 (26-03-2020)
hal-02519896 , version 2 (09-07-2020)
hal-02519896 , version 3 (16-07-2020)
hal-02519896 , version 4 (22-01-2021)
Erik Burman, Guillaume Delay, Alexandre Ern. An unfitted Hybrid High-Order method for the Stokes interface problem. IMA Journal of Numerical Analysis, 2021, 41 (4), pp.2362-2387. ⟨10.1093/imanum/draa059⟩. ⟨hal-02519896v4⟩
248 Consultations
226 Téléchargements
