Numerical Methods for Nonsmooth Dynamical Systems, Lecture Notes in Applied and Computational Mechanics, vol.35, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00423530
Implicit Euler numerical scheme and chattering-free implementation of sliding mode systems, Systems and Control Letters, vol.59, pp.284-293, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00423576
Chattering-free digital sliding-mode control with state observer and disturbance rejection, IEEE Transactions on Automatic Control, vol.57, issue.5, pp.1087-1101, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00580713
Comments on "Chattering-free digital sliding-mode control with state observer and disturbance rejection, IEEE Transactions on Automatic Control, vol.61, issue.11, p.3707, 2016. ,
A qualitative mathematical analysis of a class of linear variational inequalities via semi-complementarity problems, Applications in electronics. Mathematical Programming Series A, vol.126, issue.1, pp.31-67, 2011. ,
Well-posedness, robustness and stability analysis of a set-valued controller for Lagrangian systems, SIAM J. Control and Optimization, vol.51, issue.2, pp.1592-1614, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00825578
Implicit Euler time-discretization of a class of Lagrangian systems with set-valued robust controller, Journal of Convex Analysis, vol.23, issue.1, pp.23-52, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01313222
Sliding modes in intersecting switching surfaces: blending, Houston J. Math, vol.24, pp.545-569, 1998. ,
A new parabolic sliding mode filter augmented by a linear low-pass filter and its application to position control, ASME J. of Dynamic Systems, Measurement and Control, vol.140, p.41005, 2018. ,
An amplitude-and rate-saturated controller for linear plants, Asian Journal of Control, vol.21, issue.6, pp.1-15, 2019. ,
Parameter selection procedure for an amplitude-and rate-saturated controller, International Journal of Control, Automation and Systems, 2019. ,
An inertial proximal algorithm with dry friction: finite convergence results. Set Valued Analysis, vol.14, pp.1-23, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-00068884
Analysis and control of nonlinear singularly perturbed systems under sampling, Digital Control Systems Implementations and Computational Techniques, vol.79, pp.203-246, 1996. ,
Discretization schemes for nonlinear singularly perturbed systems, Proceedings of IEEE Int. Conference on Decision and Control, pp.443-448, 1991. ,
Numerical precision for differential inclusions with uniqueness, Mathematical Modelling and Numerical Analysis, vol.36, issue.3, pp.427-460, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-02568207
Study of an elastoplastic model with an infinite number of internal degrees of freedom, European Journal of Mechanics A/Solids, vol.21, pp.199-222, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00814955
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
Dissipative Systems Analysis and Control. Theory and Applications. Communications and Control Engineering, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-00821748
Globally stable implicit Euler time-discretization of a nonlinear single-input sliding-mode control system, Proc. IEEE 54th Int. Conf. on Decision and Control, pp.5426-5431, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01212601
The implicit discretization of the super-twisting slidingmode control algorithm, Available at hal.inria.fr, p.2336599, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02336599
Dynamical systems coupled with monotone set-valued operators: formalisms, applications, well-posedness, and stability, SIAM Review, vol.62, issue.1, pp.3-129, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02379498
Complementarity Methods in the Analysis of Piecewise Linear Dynamical Systems, 2001. ,
A pivotal method for affine variational inequalities, Mathematics of Operations Research, vol.21, pp.44-64, 1996. ,
On the discretization of a class of homogeneous differentiators, Proceedings of the 16th International Conference on Electrical Engineering, Computing Science and Automatic Control (CCE), 2019. ,
Implementation of super-twisting control: super-twisting and higher order sliding-mode observer-based approaches, IEEE Transactions on Industrial Electronics, vol.63, issue.6, pp.3677-3685, 2016. ,
The Linear Complementarity Problem. Computer Science and Scientific Computing, 1992. ,
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
Continuous dynamics related to monotone inclusions and non-smooth optimization problems. Set-Valued and Variational Analysis, 2020. ,
Difference methods for differential inclusions: A survey, SIAM Review, vol.34, issue.2, pp.263-294, 1992. ,
URL : https://hal.archives-ouvertes.fr/hal-01571241
On discrete-time sliding modes, Proc. Nonlinear Control Design Conference, pp.273-278, 1989. ,
The block control principle I. Automation and Remote Control, vol.51, pp.601-608, 1990. ,
The block control principle II. Automation and Remote Control, vol.51, pp.737-746, 1990. ,
Robustness analysis of a continuous higher order finite-time control system under sampled-data control, IEEE Transactions on Automatic Control, vol.64, issue.6, pp.2488-2494, 2019. ,
Acceleration of finite-time-stable homogeneous systems, Int. Journal of Robust and Nonlinear Control, vol.28, issue.5, pp.1757-1777, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01611961
Discretization of homogeneous systems using Euler method with a state-dependent step, Automatica, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02190206
Realization and discretization of asymptotically stable homogeneous systems, IEEE Transactions on Automatic Control, vol.62, issue.11, pp.5962-5969, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01514350
Finite-Dimensional Variational Inequalities and Complementarity Problems, volume I of Operations Research, 2003. ,
Differential equations with discontinuous right-hand sides, 1988. ,
Complex discretization behaviours of a simple sliding-mode control system, IEEE Transactions on Circuits and Systems-II: Express Briefs, vol.53, pp.652-656, 2006. ,
Euler's discretization of single input sliding-mode control systems, IEEE Transactions on Automatic Control, vol.52, issue.9, pp.1726-1730, 2007. ,
Analysis of zero-order holder discretization of two-dimensional sliding-mode control systems, IEEE Transactions on Circuits and Systems-II: Express Briefs, vol.55, issue.12, pp.1269-1273, 2008. ,
Proxy-based sliding-mode tracking control of piezoelectric-actuated nanopositioning stages, IEEE/ASME Transactions on Mechatronics, vol.20, issue.4, pp.1956-1965, 2015. ,
On the convergence of the proximal point algorithm for convex minimization, SIAM Journal on Control and Optimization, vol.29, issue.2, pp.403-419, 1991. ,
Nilpotent approximations of control systems and distributions, SIAM Journal of Control and Optimization, vol.24, issue.4, p.731, 1986. ,
Fundamentals of Convex Analysis. Grundlehren Text Editions, 2001. ,
Analyse et implémentation du contrôle par modes glissants en temps discret, 2015. ,
Enhanced matching perturbation attenuation with discretetime implementations of sliding-mode controllers, Proceedings European Control Conference, pp.2606-2611, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01066667
Lyapunov stability and performance analysis of the implicit discrete sliding mode control, IEEE Transactions on Automatic Control, vol.61, issue.10, pp.3016-3030, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01236159
Lyapunov stability analysis of the implicit discrete-time twisting control algorithm, IEEE Transactions on Automatic Control, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01622092
Implicit discrete-time twisting controller without numerical chattering: Analysis and experimental results, Control Engineering Practice, vol.46, issue.1, pp.129-141, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01066689
Experimental results on implicit and explicit time-discretization of equivalent-control-based sliding-mode control, Recent Trends in Sliding-Mode Control, number 102 in Control, Robotics and Sensors, pp.207-236, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01238120
Adaptive proxy-based controller of an active ankle foot orthosis to assist lower limb movements of paretic patients, Robotica, vol.37, pp.2147-2164, 2019. ,
Dynamics in the presence of unilateral contacts and dry friction: A numerical approach, of International Centre for Mechanical Sciences (Courses and Lectures), vol.304, pp.151-196, 1987. ,
URL : https://hal.archives-ouvertes.fr/hal-01864213
Real-time quadratic sliding mode filter for removing noise, Advanced Robotics, vol.26, issue.8-9, pp.877-896, 2012. ,
Parameter selection guidelines for a parabolic sliding mode filter based on frequency and time domain characteristics, Journal of Control Science and Engineering, 2012. ,
Improving velocity feedback for position control by using a discrete-time sliding mode filtering with adaptive windowing, Advanced Robotics, vol.14, pp.943-953, 2014. ,
A chattering-free sliding mode filter enhanced by first order derivative feedforward, IEEE Access, vol.8, pp.41175-41185, 2020. ,
Geometric homogeneity and stabilization, Proc. IFAC Nonlinear Control Symposium, pp.164-169, 1995. ,
A sliding-mode-like position controller for admittance control with bounded actuator force, IEEE/ASME Transactions on Mechatronics, vol.19, issue.5, pp.1489-1500, 2014. ,
Some stability proofs on proxy-based sliding mode control, IMA Journal of Mathematical Control and Infirmation, vol.35, pp.1319-1341, 2018. ,
Proxy-based sliding mode control for accurate and safe position control, Proceedings of IEEE International Conference on Robotics and Automation, pp.25-30, 2006. ,
Phase-lead stabilization of forceprojecting master-slave systems with a new sliding mode filter, IEEE Transactions on Control Systems Technology, vol.23, issue.6, pp.2182-2194, 2015. ,
A first-order differentiator with frst-order sliding mode filtering, Proceedings 11th IFAC Symposium on Nonlinear Control Systems (NOLCOS2019), pp.1383-1388, 2019. ,
Proxy-based sliding mode control: A safer extension of PID position control, IEEE Transactions on Robotics, vol.26, issue.4, pp.670-683, 2010. ,
Admittance and impedance representations of friction based on implicit Euler integration, IEEE Transactions on Robotics, vol.22, issue.6, pp.1176-1188, 2006. ,
Discrete-time equivalents of the super twisting algorithm, Automatica, vol.107, pp.190-199, 2019. ,
On the discretization of the super-twisting algorithm, Proceedings IEEE 58th Conference on Decision and Control, pp.5989-5994, 2019. ,
Discrete implementation of sliding mode controllers satisfying accuracy level specifications, Proceedings of the 14th International Workshop on Variable Structure Systems (VSS), pp.154-159, 2016. ,
Elements of the Theory of Functions and Functional Analysis, vol.1, 1957. ,
On linear dynamic complementary systems, IEEE Transactions on Circuits and Systems I: Fundamental Theory and Applications, vol.46, issue.8, pp.1022-1026, 1999. ,
Sliding order and sliding accuracy in sliding mode control, International Journal of Control, vol.58, issue.6, pp.1247-1263, 1993. ,
Robust exact differentiation via sliding mode technique, Automatica, vol.34, issue.3, pp.379-384, 1998. ,
Homogeneity approach to high-order sliding mode design, Automatica, vol.41, pp.823-830, 2005. ,
Quasi-continuous high-order sliding-mode controllers, IEEE Transactions on Automatic Control, vol.50, issue.11, pp.1812-1816, 2005. ,
Construction principles of 2-sliding mode design, Automatica, vol.43, issue.4, pp.576-586, 2007. ,
On fixed and finite time stability in sliding mode control, 52nd IEEE Conference on Decision and Control, pp.4260-4265, 2013. ,
Error estimates for the implicit Euler approximation of an evolution inequality, vol.15, pp.1077-1089, 1990. ,
Proper discretization of homogeneous differentiators, Automatica, vol.50, 2007. ,
Implicit Euler implementation of twisting controller and super-twisting observer without numerical chattering: precise quasi-static MEMS mirrors control, MATEC Web of Conferences, vol.256 ,
A new quick-response sliding mode tracking differentiator with its chattering-free discrete-time implementation, IEEE Access, vol.7, pp.130236-130245, 2019. ,
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.50, issue.4, pp.439-467, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00319240
Frequency-domain analysis and tunig of the algebraic differentiators, International Journal of Control, vol.91, issue.9, pp.2073-2081, 2018. ,
Multivalued robust tracking control of Lagrange systems: continuous and discrete-time algorithms, IEEE Transactions on Automatic Control, vol.62, issue.9, pp.4436-4450, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01254303
Multivalued robust tracking control of Lagrange systems: Continuous and discrete-time algorithms, IEEE Transactions on Automatic Control, vol.63, issue.8, p.2750, 2018. ,
Set-valued sliding-mode control of uncertain linear systems: continuous and discrete-time analysis, SIAM J. on Control and Optimization, vol.56, issue.3, pp.1756-1793, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01317948
Robust output regulation of strongly passive linear systems with multivalued maximally monotone controls, IEEE Transactions on Automatic Control, vol.62, issue.1, pp.238-249, 2017. ,
Continuous and discrete-time stability of a robust set-valued nested controller, Automatica, vol.107, pp.406-417, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01944920
Propriétés des applications "prox, C.R. Acad. Sci, vol.256, pp.1069-1071, 1963. ,
Unilateral contact and dry friction in finite freedom dynamics, Nonsmooth Mechanics and Applications, vol.302, pp.1-82, 1988. ,
URL : https://hal.archives-ouvertes.fr/hal-01713847
A Lyapunov approach to output feedback control using second-order sliding modes, IMA Journal of mathematical Control and Information, vol.29, issue.3, pp.291-308, 2012. ,
Strict Lyapunov functions for the super-twisting algorithm, IEEE Transactions on Automatic Control, vol.57, issue.4, pp.1035-1040, 2012. ,
A multivariable super-twisting sliding mode approach, Automatica, vol.50, pp.984-988, 2014. ,
Improving control effort in output feedback sliding mode control of sampled-data systems, IET Control Theory and Applications, vol.13, issue.13, pp.2128-2137, 2019. ,
Finite time stability and robust control synthesis of uncertain switched systems, SIAM Journal on Control and Optimization, vol.43, issue.4, pp.1253-1271, 2005. ,
Semigroups of Linear Operators and Applications to Partial Differential Equations, 1983. ,
Finite-time observers: application to secure communication, IEEE Transactions on Automatic Control, vol.53, issue.1, pp.356-360, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00176758
Evolution equations for maximal monotone operators: asymptotic analysis n continuous and discrete time, Journal of Convex Analysis, vol.17, issue.3-4, pp.1113-1163, 2010. ,
Sliding mode control design using canonical homogeneous norm, International Journal of Robust and Nonlinear Control, vol.29, issue.3, pp.682-701, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01697797
Generalized Homogeneity in Systems and Control, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02426338
On consistent discretization of finite-time stable homogeneous differential inclusions, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02514847
Consistent discretization of finite-time and fixed-time stable systems, SIAM Journal of Control and Optimization, vol.57, issue.1, pp.78-103, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01838712
Finite-time and fixed-time stabilization: Implicit Lyapunov function approach, Automatica, vol.51, issue.1, pp.332-340, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01098099
Robust stabilization of MIMO systems in finite/fixed time, International Journal of Robust and Nonlinear Control, vol.26, issue.1, pp.69-90, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01160052
Stability notions and Lyapunov functions for sliding mode control systems, Journal of The Franklin Institute, vol.351, issue.4, pp.1831-1865, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942319
Reaching time estimation for "super-twisting" second order sliding mode controller via Lyapunov function designing, IEEE Transactions on Automatic Control, vol.54, issue.8, pp.1951-1955, 2009. ,
Proxy-based sliding mode control on platform of 3 degree of freedom (3-DOF), Advanced Robotics, vol.27, issue.10, pp.773-784, 2013. ,
Generalized equations, Mathematical Programing: The State of the Art, pp.346-367, 1982. ,
Homogenous Lyapunov function for homogenous coninuous vector field, System & Control Letters, vol.19, pp.467-473, 1992. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.15, issue.3, pp.273-283, 1966. ,
Design of Lyapunov functions for a class of homogeneous systems: Generalized forms approach, International Journal of Robust and Nonlinear Control, vol.29, issue.3, pp.661-681, 2019. ,
Stability proof for a well-established super-twisting parameter setting, Automatica, vol.84, pp.241-243, 2017. ,
Twisting sliding mode control with adaptation: Lyapunov design, methodology and application, Automatica, vol.75, pp.229-235, 2017. ,
An O(T 2 ) boundary layer in sliding mode for sampleddata systems, IEEE Transactions on Automatic Control, vol.45, issue.3, pp.482-485, 2000. ,
Design of continuous twisting algorithm, Automatica, vol.80, pp.119-126, 2017. ,
Sliding Modes in Control Optimization, Communications and Control Engineering, 1992. ,
Sliding-mode control in discrete-time and difference systems, Variable Structure and Lyapunov Control, vol.193, pp.87-107, 1994. ,
Block control principle for mechanical systems, ASME Journal of Dynamic Systems, Measurements and Control, vol.122, pp.1-10, 2000. ,
A hierarchical principle of the control system decomposition based on motion separation, Proceedings 9th IFAC Triennal World Congress, pp.1553-1558, 1984. ,
Experimental comparisons between implicit and explicit implementations of discrete-time sliding mode controllers: Toward input and output chattering suppression, Control Systems Technology, vol.23, issue.5, pp.2071-2075, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01625866
ZOH discretisation effect on single-input sliding mode control systems with matched uncertainties, Automatica, vol.45, issue.1, pp.118-125, 2009. ,
Semi-implicit discretization of the uniform robust exact differentiator, Proceedings IEEE 58th Conference on Decision and Control, pp.5995-6000, 2019. ,
Robust trajectory tracking for incrementally passive nonlinear systems, Automatica, vol.107, issue.9, pp.595-599, 2019. ,
Discrete-time implementation of continuous terminal algorithm with implicit-Euler method, IEEE Access, vol.7, pp.175940-175946, 2019. ,
Implicit-Euler implementation of super-twisting observer and twisting controller for second-order systems, IEEE Transactions on Circuits and Systems II: Express Briefs, 2020. ,
Backward-Euler discretization of second-order sliding mode control and super-twisting observer for accurate position control, Proc. ASME Dynamic Systems and Control Conference DSCC2013, pp.2013-3872, 2013. ,
A differential algebraic method to approximate nonsmooth mechanical systems by ordinary differential equations, Journal of Applied Mathematics, 2013. ,
Euler's discretization effect on a twisting algorithm based sliding mode control, Automatica, vol.68, pp.203-208, 2016. ,
Quantized super-twisting algorithm based sliding mode control. Automatica, vol.105, pp.43-48, 2019. ,
Discretization behaviors of a super-twisting algoriothm based sliding mode control system, Proceedings of the International Workshop on Recent Advances in Sliding Modes (RASM), 2015. ,
A control engineer's guide to sliding mode control, IEEE Transactions on Control Systems Technology, vol.7, issue.3, pp.328-342, 1999. ,
Discretization behaviors of equivalent control based sliding-mode control systems, IEEE Transactions on Automatic Control, vol.48, issue.9, pp.1641-1646, 2003. ,
Discretisation effect on equivalent control-based multiinput sliding-mode control systems, IEEE Transactions on Automatic Control, vol.53, issue.6, pp.1563-1569, 2008. ,
A super-twisting observer for atomic-force reconstruction in a probe microscope, Control Engineering Practice, vol.94, p.2020, 104191. ,
On dynamical feedback control design for generalized homogeneous differential inclusions, Proceedings IEEE Conference on Decision and Control, pp.4785-4790, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01872548
On systems of ordinary differential equations with generalized homogenous right-hand sides. Izvestia vuzov, Mathematica (in Russian), vol.1, pp.80-88, 1958. ,
