System Identification: Theory for User, 1987. ,
Adaptive control: Stability, convergence, and robustness, 1989. ,
Robust Adaptive Control, 1996. ,
URL : https://hal.archives-ouvertes.fr/hal-01394197
Adaptive controllers for discrete-time systems with arbitrary zeros: An overview, Automatica, vol.21, issue.4, pp.413-423, 1985. ,
Adaptive filtering prediction and control, Courier Corporation, 2014. ,
Reinforcement Learning and Feedback Control: Using Natural Decision Methods to Design Optimal Adaptive Controllers, IEEE Control Systems, vol.32, issue.6, pp.76-105, 2012. ,
Design of impulsive adaptive observers for improvement of persistency of excitation, International Journal of Adaptive Control and Signal Processing, vol.29, issue.6, pp.765-782, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01016332
Performance Enhancement of Parameter Estimators via Dynamic Regressor Extension and Mixing*, IEEE Transactions on Automatic Control, vol.62, issue.7, pp.3546-3550, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01612256
On dynamic regressor extension and mixing parameter estimators: Two Luenberger observers interpretations, Automatica, vol.95, pp.548-551, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01817817
Relaxing the highfrequency gain sign assumption in direct model reference adaptive control, European Journal of Control, vol.43, pp.12-19, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01895403
A globally convergent frequency estimator of a sinusoidal signal with a time-varying amplitude, European Journal of Control, vol.38, pp.32-38, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01612130
A robust nonlinear position observer for synchronous motors with relaxed excitation conditions, International Journal of Control, vol.90, issue.4, pp.813-824, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01612227
Online Estimation of Power System Inertia Using Dynamic Regressor Extension and Mixing, IEEE Transactions on Power Systems, pp.1-1, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02419404
Identification of photovoltaic arrays' maximum power extraction point via dynamic regressor extension and mixing, International Journal of Adaptive Control and Signal Processing, vol.31, issue.9, pp.1337-1349, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01612222
New Results on Parameter Estimation via Dynamic Regressor Extension and Mixing: Continuous and Discrete-time Cases, Submitted to IEEE Transactions on Automatic Control, 2019. ,
Parameter identification of linear time-invariant systems using dynamic regressor extension and mixing, International Journal of Adaptive Control and Signal Processing, vol.33, issue.6, pp.1016-1030, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02181842
Adaptive observers with exponential rate of convergence, IEEE Transactions on Automatic Control, vol.22, issue.1, pp.2-8, 1977. ,
Performance improvement of discrete mrac by dynamic and memory regressor extension, 2019 18th European Control Conference (ECC), pp.2950-2956, 2019. ,
On global asymptotic stability of? = ??(t)? (t)x with ?(t) not persistently exciting, Systems & Control Letters, vol.109, pp.24-29, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01816386
On robust parameter estimation in finite-time without persistence of excitation, IEEE Transactions on Automatic Control, vol.65, issue.4 ,
URL : https://hal.archives-ouvertes.fr/hal-02196992
Composite Model Reference Adaptive Control with Parameter Convergence Under Finite Excitation, IEEE Transactions on Automatic Control, vol.63, issue.3, pp.811-818, 2018. ,
Fixedtime parameter estimation in polynomial systems through modulating functions, 2016 IEEE 55th Conference on Decision and Control (CDC), pp.2067-2072, 2016. ,
