Optimized weak coupling of boundary element and finite element methods for acoustic scattering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2020
In this paper we present an optimized weak coupling of boundary element and finite element methods to solve acoustic scattering problems. This weak coupling is formulated as a non-overlapping Schwarz domain decomposition method, where the transmission conditions are constructed through Padé localized approximations of the Dirichlet-to-Neumann map. The performance of the resulting formulations is analyzed on several three-dimensional examples, with both homogeneous and inhomogeneous scatterers.
acoustic_weakCoupling.pdf (1.44 Mo) Télécharger le fichier
hal-02524580 , version 1 (30-03-2020)
Boris Caudron, Xavier Antoine, Christophe Geuzaine. Optimized weak coupling of boundary element and finite element methods for acoustic scattering. Journal of Computational Physics, 2020, 421, ⟨10.1016/j.jcp.2020.109737⟩. ⟨hal-02524580⟩
120 Consultations
110 Téléchargements
