The effect of vortex generators on a jet in a cross-flow, Phys. Fluids, vol.9, issue.1, pp.106-114, 1997. ,
Flow past a trapezoidal tab, J. Fluid Mech, vol.510, pp.219-242, 2004. ,
Streamwise evolution of longitudinal vortices in a turbulent boundary layer, J. Fluid Mech, vol.623, pp.27-58, 2009. ,
Residence time distribution and heat transfer in circular pipe fitted with longitudinal rectangular wings, Int. J. Heat Mass Transfer, vol.74, pp.13-24, 2014. ,
Static mixers: Mechanisms, applications, and characterization methods-A review, Chem. Eng. Res. Des, vol.92, issue.2, pp.205-228, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01390619
High-Reynolds-number experiments: The challenge of understanding universality in turbulence, Fluid Dyn. Res, vol.41, pp.1-17, 2009. ,
, Turbulent Flow, 2000.
Local structure of turbulence in an incompressible viscous fluid at very high Reynolds numbers, Dokl. Akad. Nauk SSSR, vol.30, pp.301-305, 1941. ,
The mixing transition in turbulent flows, J. Fluid Mech, vol.409, pp.69-98, 2000. ,
The velocity spectra and turbulence length scale distributions, Phys. Fluids, vol.21, p.115101, 2009. ,
Elastic turbulence in von Karman swirling flow between two disks, Phys. Fluids, vol.19, issue.5, p.53104, 2007. ,
Kolmogorov-kraichnan scaling in the inverse energy cascade of two-dimensional plasma turbulence, Phys. Rev. Lett, vol.91, issue.5, p.55002, 2003. ,
On integral length scales in anisotropic turbulence, Phys. Fluids, vol.24, issue.6, p.61702, 2012. ,
Geometrical influence on vortex shedding in turbulent axisymmetric wakes, Phys. Fluids, vol.27, issue.3, p.35103, 2015. ,
, Turbulent Mixing and Chemical Reactions, 1999.
Mixing assessment by chemical probe, J. Ind. Eng. Chem, vol.20, pp.1411-1420, 2014. ,
Turbulently flowing liquid-liquid dispersions. Part I. Drop breakage and coalescence, Chem. Eng. J, vol.166, pp.715-725, 2011. ,
Universal dissipation scaling for nonequilibrium turbulence, Phys. Rev. Lett, vol.108, issue.21, p.214503, 2012. ,
Static mixers in the process industries-A review, Chem. Eng. Res. Des, vol.81, issue.7, pp.787-826, 2003. ,
Energy efficiency in process industry-Highefficiency vortex (HEV) multifunctional heat exchanger, Renewable Energy, vol.56, pp.96-104, 2013. ,
Flow structure and heat transfer induced by embedded vorticity, Int. J. Heat Mass Transfer, vol.53, pp.3575-3584, 2010. ,
Turbulence behavior of artificially generated vorticity, J. Turbul, vol.11, p.36, 2010. ,
Towards better uncertainty estimates for turbulence statistics, Exp. Fluids, vol.22, issue.2, pp.129-136, 1996. ,
Spectral estimation for random sampling using interpolation, Signal Process, vol.46, issue.3, pp.297-313, 1995. ,
Structure of turbulent velocity and scalar fields at large wave-numbers, Phys. Fluids, vol.8, pp.1063-1075, 1965. ,
, The Theory of Homogeneous Turbulence, 1953.
Interpretation of time spectra measured in high-intensity shear flows, Phys. Fluids, vol.8, p.1056, 1965. ,
On the universality of the Kolmogorov constant, Phys. Fluids, vol.7, issue.11, pp.2778-2784, 1995. ,
On the receptivity of the by-pass transition to the length scale of the outer stream turbulence, Eur. J. Mech., B: Fluids, vol.19, issue.5, pp.707-722, 2000. ,
Effect of turbulent integral length scale on heat transfer around a circular cylinder placed cross to an air flow, Exp. Therm. Fluid Sci, vol.26, issue.5, pp.455-460, 2002. ,
Alternating mixing tabs in multifunctional heat exchangerreactor, Chem. Eng. Process.: Process Intensif, vol.49, issue.7, pp.653-661, 2010. ,
, Turbulence: The Legacy of A. N. Kolmogorov, 1995.
On the scaling of the turbulence energy dissipation rate, Phys. Fluids, vol.27, issue.5, pp.1048-1051, 1958. ,
On the normalized turbulent energy dissipation rate, Phys. Fluids, vol.17, issue.9, p.98103, 2005. ,
The integral scale in homogeneous isotropic turbulence, J. Fluid Mech, vol.459, p.429, 2002. ,
The structure of intense vorticity in isotropic turbulence, J. Fluid Mech, vol.255, pp.65-90, 1993. ,
Energy dissipation rate and energy spectrum in high resolution direct numerical simulations of turbulence in a periodic box, Phys. Fluids, vol.15, issue.2, p.21, 2003. ,
Velocity field statistics in homogeneous steady turbulence obtained using a high-resolution direct numerical simulation, Phys. Fluids, vol.14, issue.3, p.1065, 2002. ,
Hydrodynamics of liquid flow through screens and screen-type static mixers, Chem. Eng. Commun, vol.198, issue.5, pp.726-742, 2011. ,
