Superpixels and polygons using simple non-iterative clustering, CVPR, vol.1, 2017. ,
Efficient interactive annotation of segmentation datasets with polygon-rnn++, CVPR, 2018. ,
Kippi: Kinetic polygonal partitioning of images, CVPR, p.6, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-01740958
Polygon Mesh Processing, vol.3, p.7, 2010. ,
URL : https://hal.archives-ouvertes.fr/inria-00538098
Annotating object instances with a polygon-rnn, CVPR, 2017. ,
Encoder-decoder with atrous separable convolution for semantic image segmentation, ECCV, 2018. ,
Global contrast based salient region detection, vol.37, 2015. ,
Best practices for elegant experimentation in data science projects, 2018. ,
An optimal transport approach to robust reconstruction and simplification of 2d shapes, Computer Graphics Forum, vol.30, issue.5, 2002. ,
URL : https://hal.archives-ouvertes.fr/hal-00758019
Structured forests for fast edge detection, ICCV, 2013. ,
Image partitioning into convex polygons, CVPR, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01140320
Simultaneous curve simplification, Journal of Geographical Systems, vol.11, issue.3, p.6, 2002. ,
The PASCAL Visual Object Classes Challenge 2012 (VOC2012) Results ,
Extracting geometric structures in images with delaunay point processes, vol.42 ,
URL : https://hal.archives-ouvertes.fr/hal-01950791
Simplicity: a Global Approach to Line Drawing Vectorization, ACM Trans. on Graphics, vol.35, issue.4, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01309271
Resolution independent superpixels based on convex constrained meshes without small angles, International Symposium on Visual Computing, vol.1, 2016. ,
Surface simplification using quadric error metrics, SIGGRAPH, vol.3, p.7, 1997. ,
Combining region splitting and edge detection through guided delaunay image subdivision, CVPR, 1997. ,
End-to-End Learning of Polygons for Remote Sensing Image Classification, IGARSS, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01762446
Mask R-CNN, ICCV, 2017. ,
Crisp boundary detection using pointwise mutual information, ECCV, 2014. ,
Image segmentation by polygonal markov fields, Annals of the Institute of Statistical Mathematics, vol.59, issue.3, 2007. ,
Optimal contour closure by superpixel grouping, ECCV, 2010. ,
Deep contrast learning for salient object detection, CVPR, vol.2, p.6, 2016. ,
Topological map extraction from overhead images, ICCV, vol.2, p.7, 2019. ,
Segmentation using superpixels: A bipartite graph partitioning approach, CVPR, 2012. ,
Raster-to-vector: Revisiting floorplan transformation, ICCV, 2017. ,
Path aggregation network for instance segmentation, In CVPR, issue.7, 2018. ,
Crowdai dataset: the mapping challenge ,
Crowdai mapping challenge : Baseline with mask r-cnn ,
Point set shape detection. In CGAL User and Reference Manual, 2018. ,
Image segmentation by cascaded region agglomeration, CVPR, 2013. ,
Grabcutinteractive foreground extraction using iterated graph cuts, ACM Trans. on Graphics, vol.23, issue.3, 2004. ,
Free-shape polygonal object localization, ECCV, 2014. ,
, The CGAL Project. CGAL, computational geometry algorithms library
Lsd: A fast line segment detector with a false detection control, vol.32, 2010. ,
Saliency detection with recurrent fully convolutional networks, ECCV, 2016. ,
A non-self-intersection Douglas-Peucker algorithm, IEEE Symposium on Computer Graphics and Image Processing, vol.1, p.6, 2003. ,
Superedge grouping for object localization by combining appearance and shape informations, CVPR, 2012. ,
