Generating Biased Dataset for Metamorphic Testing of Machine Learning Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Although both positive and negative testing are important for assuring quality of programs, generating a variety of test inputs for such testing purposes is difficult for machine learning software. This paper studies why it is difficult, and then proposes a new method of generating datasets that are test inputs to machine learning programs. The proposed idea is demonstrated with a case study of classifying hand-written numbers.
482770_1_En_4_Chapter.pdf (515.33 Ko) Télécharger le fichier
hal-02526339 , version 1 (31-03-2020)
Paternité
Shin Nakajima, Tsong Yueh Chen. Generating Biased Dataset for Metamorphic Testing of Machine Learning Programs. 31th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2019, Paris, France. pp.56-64, ⟨10.1007/978-3-030-31280-0_4⟩. ⟨hal-02526339⟩
57 Consultations
67 Téléchargements
