Foundations of Databases, 1995. ,
Diversified stress testing of RDF data management systems, ISWC, pp.197-212, 2014. ,
The Berlin SPARQL Benchmark, Int. J. Semantic Web Inf. Syst, vol.5, issue.2, 2009. ,
From XML schema to relations: A cost-based approach to XML storage, 2002. ,
Efficiency and precision trade-offs in graph summary algorithms, p.IDEAS, 2013. ,
Compact Summaries of Rich Heterogeneous Graphs, INRIA and U. Rennes, vol.1, 2018. ,
Summarizing Semantic Graphs: A Survey, The VLDB Journal, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01925496
A framework for efficient representative summarization of RDF graphs, ISWC (poster, 2017. ,
Mining graph patterns efficiently via randomized summaries, PVLDB, vol.2, issue.1, 2009. ,
D(K)-index: An adaptive structural summary for graph-structured data, 2003. ,
, Exploring XML web collections with DescribeX. TWEB, vol.4, issue.3, 2010.
Storing semistructured data with STORED, 1999. ,
Query preserving graph compression, 2012. ,
Data structures and algorithms for disjoint set union problems, ACM Comput. Surv, vol.23, issue.3, pp.319-344, 1991. ,
Incremental structural summarization of RDF graphs, EDBT, 2019. ,
Efficient query answering against dynamic RDF databases, 2013. ,
Dataguides: Enabling query formulation and optimization in semistructured databases, 1997. ,
Exploiting the query structure for efficient join ordering in SPARQL queries, EDBT, pp.439-450, 2014. ,
LUBM: A benchmark for OWL knowledge base systems, J. Web Sem, vol.3, issue.2-3, 2005. ,
Using graph summarization for join-ahead pruning in a distributed RDF engine, SWIM Workshop, 2014. ,
, Computing simulations on finite and infinite graphs, 1995.
Covering indexes for branching path queries, 2002. ,
Exploiting local similarity for indexing paths in graphstructured data, 2002. ,
Set-based approximate approach for lossless graph summarization, Computing, vol.97, issue.12, pp.1185-1207, 2015. ,
ExpLOD: Summary-based exploration of interlinking and RDF usage in the linked open data cloud, 2010. ,
Constructing bisimulation summaries on a multi-core graph processing framework, GRADES Workshop, 2015. ,
Scalable keyword search on large RDF data, IEEE TKDE, vol.26, issue.11, 2014. ,
GraSS: Graph structure summarization, SDM, 2010. ,
Graph summarization methods and applications: A survey, ACM Comput. Surv, vol.51, issue.3, 2018. ,
Index structures for path expressions, 1999. ,
Graph summarization with bounded error, 2008. ,
Characteristic sets: Accurate cardinality estimation for RDF queries with multiple joins, 2011. ,
ABSTAT 1.0: Compute, manage and share semantic profiles of RDF knowledge graphs, 2018. ,
SynopSys: large graph analytics in the SAP HANA database through summarization, 2013. ,
Large-scale bisimulation of RDF graphs, SWIM Workshop, 2013. ,
Efficient aggregation for graph summarization, 2008. ,
Managing structured and semistructured RDF data using structure indexes, IEEE TKDE, vol.25, issue.9, 2013. ,
, W3C: Resource description framework
Graph indexing: Tree + delta >= graph, 2007. ,
Quality metrics for RDF graph summarization, Semantic Web, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01773457
, ? , by definition of an RDF summary, there ex-2 = f (n 1 ) p f (n 2 ). Moreover, since n 1 p n 2 is in G ? , f 1 (n 1 ) p f 1 (n 2 ) is in (G ? ) /? . Therefore, since for every f, vol.2, p.1
? such that n 1 type c = f 1 (n 1 ) type c. Further, if n 1 type c is in G ? , then f (n 1 ) type c is in (G /? ) ? (Theorem 1), hence f 2 (f (n 1 )) type c is in ((G /? ) ? ) /? . Therefore, ? since for every f 1 (n 1 ) type c edge in (G ? ) /? , there is an edge f 2 (f (n 1 )) type c in ((G /? ) ? ) /? , and ? since ?(f 1 (n)) = f 2 (f (n)), for n any G ? node, is a bijective function from all (G ? ) /? nodes to all, G ? ) /? , by definition of an RDF summary ,
, ? , by definition of an RDF summary, there exists an in (G ? ) /? . Therefore, since for every f 2 (f (n 1 )) type c edge in ((G /? ) ? ) /? , there is an edge f 1 (n 1 ) type c in (G ? ) /? , and since ?(f 1 (n)) = f 2 (f (n)), for n any G ? node, is a bijective function from all (G ? ) /? nodes to all, ? n 1 type c triples through ? ?1 (**'). From (*) and (**), and, (*') and (**')
