Karim Belabas - S-units and compact representations in number fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vidéo Année : 2020
Afficher
Huge algebraic numbers are problematic because - computing with them algebraically is expensive; - approximations via floating point embeddings into C require huge accuracy (cancellation); - they are often intermediate results: we do not want a result in K but in K∗/(K∗)2, or in - ZK/pk, or a floating point approximation to complex embeddings, or . . . - they may overflow the possibilities of the implementation: try 22100 .
hal-02530400 , version 1 (02-04-2020)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-02530400 , version 1
Karim Belabas, Fanny Bastien. Karim Belabas - S-units and compact representations in number fields. 2020. ⟨hal-02530400⟩
157 Consultations
1 Téléchargements
