Analyzing Windows Subsystem for Linux Metadata to Detect Timestamp Forgery
Timestamp patterns assist forensic analysts in detecting user activities, especially operations performed on files and folders. However, the Windows Subsystem for Linux feature in Windows 10 versions 1607 and later enables users to access and manipulate NTFS files using Linux command-line tools within the Bash shell. Therefore, forensic analysts should consider the timestamp patterns generated by file operations performed using Windows command-line utilities and Linux tools within the Bash shell.This chapter describes the identification of timestamp patterns of various file operations in stand-alone NTFS and Ext4 filesystems as well as file interactions between the filesystems. Experiments are performed to analyze the anti-forensic capabilities of file timestamp changing utilities – called timestomping tools – on NTFS and Ext4 filesystems. The forensic implications of timestamp patterns and timestomping are also discussed.
Informatique [cs]
