A Preliminary Attempt to Apply Detection and Estimation Theory to Intrusion Detection, 2000. ,
Differential fault analysis of secret key cryptosystems, Proceedings of the Seventeenth Annual International Cryptology Conference, pp.513-525, 1997. ,
Atomic force microscope, Physical Review Letters, vol.56, pp.930-933, 1986. ,
Scanning tunneling microscopy, Helvetica Physica Acta, vol.55, pp.726-735, 1982. ,
, , 2019.
Dynamic EFM spectroscopy studies on electric force gradients of IrO 2 nanorod arrays, Nanotechnology, vol.16, issue.3, pp.35-40, 2005. ,
Direct measurements of charge in floating gate transistor channels of flash memories using scanning capacitance microscopy, Proceedings of the Thirty-Second International Symposium on Testing and Failure Analysis, pp.86-93, 2006. ,
, Digital forensics research: The next 10 years, Digital Investigation, vol.7, pp.64-73, 2010.
Why Can't Apple Decrypt Your iPhone, A Few Thoughts on Cryptography Engineering Blog, 2014. ,
Lest we remember: Cold-boot attacks on encryption keys, Communications of the ACM, vol.52, issue.5, pp.91-98, 2009. ,
A wearable multiplexed silicon nonvolatile memory array using nanocrystal charge confinement, Science Advances, vol.2, issue.1, 2016. ,
Trusted Platform Module Basics: Using TPM in Embedded Systems, 2006. ,
, Differential power analysis, Proceedings of the Nineteenth Annual International Cryptology Conference, pp.388-397, 1999.
Forensic Applications of Atomic Force Microscopy, Doctoral Dissertation, Department of Electronic and Electrical Engineering, 2013. ,
Tapping mode microwave impedance microscopy, Review of Scientific Instruments, vol.80, issue.4, p.43707, 2009. ,
High-stroke silicon-on-insulator MEMS nanopositioner: Control design for nonraster scan atomic force microscopy, Review of Scientific Instruments, vol.86, issue.2, p.23705, 2015. ,
, Spin-Stand Microscopy of Hard Disk Data, 2007.
Electrical Characterization of Semiconductor Device Using SCM and SKPM Imaging, Application Note #8, Park Systems, 2017. ,
Thinking about firewalls, Proceedings of the Second International Conference on Systems and Network Security and Management, 1993. ,
A trusted computing base for embedded systems, Proceedings of the Seventh Department of Defense/National Bureau of Standards Computer Security Conference, pp.294-311, 1984. ,
Optical fault induction attacks, Proceedings of the Fourth International Workshop on Cryptographic Hardware and Embedded Systems, pp.2-12, 2002. ,
Cryptography and Network Security: Principles and Practice, 2010. ,
Information flow control revisited: Noninfluence = noninterference + nonleakage, Proceedings of the Ninth European Symposium on Research in Computer Security, pp.225-243, 2004. ,
Tamper evident microprocessors, Proceedings of the IEEE Symposium on Security and Privacy, pp.173-188, 2010. ,
