Predictable Efficiency for Reconfiguration of Service-Oriented Systems with Concerto - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dynamic reconfiguration of distributed software systems is nowadays gaining interest because of the emergence of dynamic IoT and smart applications as well as large scale dynamic infrastructures (e.g., Fog and Edge computing). When quality of service and experience is of prime importance, efficient reconfiguration is necessary, as well as performance predictability to decide when a reconfiguration should occur. This paper tackles the problem of efficient execution of a reconfiguration plan and its predictability with Concerto, a reconfiguration model supporting a high level of parallelism. Evaluation performed on synthetic cases and on two real production scenarios show that Concerto provides better performance than state-of-the-art systems with accurate time estimation.
main.pdf (565.9 Ko) Télécharger le fichier
hal-02535077 , version 1 (12-06-2020)
Maverick Chardet, Hélène Coullon, Christian Pérez. Predictable Efficiency for Reconfiguration of Service-Oriented Systems with Concerto. CCGrid 2020 : 20th IEEE/ACM International Symposium on Cluster, Cloud and Internet Computing, May 2020, Melbourne, Australia. ⟨10.1109/CCGrid49817.2020.00-59⟩. ⟨hal-02535077⟩
374 Consultations
409 Téléchargements
