Abstract : A new theory of homogeneity for neutral type systems with application to fast stabilization of the 2nd-order integrator is proposed. It is assumed that only the position is available for measurements, and the designed feedback uses the output and its delayed values without an estimation of velocity. It is shown that by selecting the closed-loop system to be homogeneous with negative or positive degree, it is possible to accelerate the rate of convergence in the system at the price of a small steady-state error. Robustness of the developed stabilization strategy with respect to exogenous perturbations is investigated. The efficiency of the proposed control is demonstrated in simulations.
