On homogeneity and its application in sliding mode, International Journal of Franklin Institute, vol.351, issue.4, pp.1866-1901, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00942326
, Liapunov Functions and Stability in Control Theory, vol.267, 2001.
URL : https://hal.archives-ouvertes.fr/hal-00139067
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
, of Progress in systems and control theory: New trends in systems theory. Birkhäuser, vol.7, 1991.
On systems of ordinary differential equations with generalized homogenous right-hand sides, Izvestia vuzov. Mathematica, vol.1, pp.80-88, 1958. ,
Homogeneity based uniform stability analysis for time-varying systems, IEEE Trans. Automatic Control, vol.61, issue.3, pp.725-734, 2016. ,
Homogeneous time-varying systems: Robustness analysis, IEEE Trans. Automatic Control, vol.61, issue.12, pp.4075-4080, 2016. ,
Development of homogeneity concept for time-delay systems, SIAM J. Control Optim, vol.52, issue.3, pp.1403-1808, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00956878
Weighted homogeneity for time-delay systems: Finite-time and independent of delay stability, IEEE Trans. Automatic Control, vol.61, issue.1, pp.1-6, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01145321
On the asymptotic stability of solutions of nonlinear systems with delay, Siberian Mathematical Journal, vol.53, issue.3, pp.393-403, 2012. ,
Analytical solution of a system of homogeneous delay differential equations via the Lambert function, Proc. American Control Conference, pp.2496-2500, 2000. ,
Dstability and delay-independent stability of homogeneous cooperative systems, IEEE Trans. Automatic Control, vol.55, issue.12, pp.2882-2885, 2010. ,
Asymptotic equilibrium for homogeneous delay linear differential equations with l-perturbation term, Nonlinear Analysis, Theory, Methods & Applicarions, vol.30, issue.6, pp.3927-3933, 1997. ,
Comments on finite-time stability of time-delay systems, Automatica, vol.50, issue.7, pp.1944-1947, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-00986004
Homogeneous Lyapunov function for homogeneous continuous vector field, Systems&Control Lett, vol.19, pp.467-473, 1992. ,
Oscillations conditions in homogenous systems, Proc. NOLCOS'10, pp.1379-1384, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00561003
, , 2003.
Introduction to Time-Delay Systems: Analysis and Control, 2014. ,
Delay-induced stability of vector second-order systems via simple Lyapunov functionals, Automatica, vol.74, pp.288-296, 2016. ,
Stabilization by using artificial delays: An LMI approach, Automatica, vol.81, pp.429-437, 2017. ,
Implicit Lyapunov-Krasovski functionals for stability analysis and control design of time-delay systems, IEEE Transactions on Automatic Control, vol.60, issue.12, pp.3344-3349, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01160061
On hyper-exponential output-feedback stabilization of a double integrator by using artificial delay, Proc. 17th European Control Conference (ECC), (Limassol), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01755086
Stability of functional differential equations, 1986. ,
On input-to-state stability of systems with time-delay: A matrix inequalities approach, Automatica, vol.44, issue.9, pp.2364-2369, 2008. ,
Connections between Razumikhin-type theorems and the ISS nonlinear small gain theorem, IEEE Trans. Automat. Control, vol.43, issue.7, pp.960-964, 1998. ,
A Lyapunov-Krasovskii methodology for ISS and iISS of time-delay systems, Systems & Control Letters, vol.55, issue.12, pp.1006-1014, 2006. ,
Homogeneity for time-delay systems, Proc. IFAC WC, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00628890
, Theory of Functional Differential Equations, 1977.
