Comparison of tail index estimators, Stat. Neerl, vol.52, issue.1, pp.60-70, 1998. ,
A moment estimator for the index of an extreme-value distribution, Ann. Stat, vol.17, issue.4, pp.1833-1855, 1989. ,
Induced cores and their use in robust parametric estimation, Communications in Statistics -Theory and Methods, vol.30, issue.3, pp.537-555, 2001. ,
A new class of semi-parametric estimators of the second order parameter, pp.193-214, 2003. ,
Alternatives to a semi-parametric estimator of parameters of rare events-the jackknife methodology*, Extremes, vol.3, issue.3, pp.207-229, 2000. ,
A simple general approach to inference about the tail of a distribution, Ann. Stat, vol.3, pp.1163-1174, 1975. ,
Weak properties and robustness of t-hill estimators, Extremes, vol.19, issue.4, pp.591-626, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01327002
On ecosystems dynamics, Ecological Complexity, vol.29, pp.10-29, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01394734
Asymptotically unbiased estimators for the extreme-value index, Statistics & Probability Letters, vol.38, issue.2, pp.160-160, 1998. ,
On the law of the iterated logarithm, Ann. Probab, vol.2, issue.4, pp.714-728, 1974. ,
