On the Combined Impact of Population Size and Sub-problem Selection in MOEA/D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper intends to understand and to improve the working principle of decomposition-based multi-objective evolutionary algorithms. We review the design of the well-established Moea/d framework to support the smooth integration of different strategies for sub-problem selection, while emphasizing the role of the population size and of the number of offspring created at each generation. By conducting a comprehensive empirical analysis on a wide range of multi-and many-objective combinatorial NK landscapes, we provide new insights into the combined effect of those parameters on the anytime performance of the underlying search process. In particular, we show that even a simple random strategy selecting sub-problems at random outperforms existing sophisticated strategies. We also study the sensitivity of such strategies with respect to the ruggedness and the objective space dimension of the target problem.
EVOCOP_2020(5).pdf (2.81 Mo) Télécharger le fichier
hal-02540291 , version 1 (14-04-2020)
Geoffrey Pruvost, Bilel Derbel, Arnaud Liefooghe, Ke Li, Qingfu Zhang. On the Combined Impact of Population Size and Sub-problem Selection in MOEA/D. EvoCOP 2020 - 20st European Conference on Evolutionary Computation in Combinatorial Optimization, Apr 2020, Seville, Spain. ⟨10.1007/978-3-030-43680-3_9⟩. ⟨hal-02540291⟩
71 Consultations
67 Téléchargements
