Finding the needle in a high-dimensional haystack: Canonical correlation analysis for neuroscientists - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2020
The 21st century marks the emergence of “big data” with a rapid increase in the availability of datasets with multiple measurements. In neuroscience, brain-imaging datasets are more commonly accompanied by dozens or even hundreds of phenotypic subject descriptors on the behavioral, neural, and genomic level. The complexity of such “big data” repositories offer new opportunities and pose new challenges for systems neuroscience. Canonical correlation analysis (CCA) is a prototypical family of methods that is useful in identifying the links between variablesets from different modalities. Importantly, CCA is well suited to describing relationships across multiple sets of data and so is well suited to the analysis of big neuroscience datasets. Our primer discusses the rationale, promises, and pitfalls of CCA
MS_CCA_R3_plain.pdf (1.64 Mo) Télécharger le fichier
hal-02541124 , version 1 (12-04-2020)
  • HAL Id : hal-02541124 , version 1
Hao-Ting Wang, Jonathan Smallwood, Janaina Mourao-Miranda, Cedric Huchuan Xia, Theodore D Satterthwaite, et al.. Finding the needle in a high-dimensional haystack: Canonical correlation analysis for neuroscientists. NeuroImage, 2020. ⟨hal-02541124⟩
95 Consultations
852 Téléchargements
