A Time-independent Deformer for Elastic-rigid Contacts
We introduce a new tool that assists artists in deforming an elastic object when it comes in intersection with a rigid one. As opposed to methods that rely on time-resolved simulations, our approach is entirely based on time-independent geometric operators. It thus restarts from scratch at every frame from a pair of objects in intersection and works in two stages: the intersected regions are first matched and a contact region is identified on the rigid object; the elastic object is then deformed to match the contact while producing plausible bulge effects with controllable volume preservation. Our direct deformation approach brings several advantages to 3D animators: it provides instant feedback, permits non-linear editing, allows for the replicability of the deformation in different settings, and grants control over exaggerated or stylized bulging effects.
DeformerElastic-rigid_paper.pdf (37.68 Mo)
Télécharger le fichier
DeformerElastic-rigid_video.mov (171.66 Mo)
Format : Figure, Image
Format : Video
