Designer Led Computational Approach to Generate Mappings for Devices with Low Gestural Resolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roberto Montano-Murillo
  • Fonction : Auteur
  • PersonId : 1068023
Teng Han
  • Fonction : Auteur
  • PersonId : 1068024
Pourang Irani
  • Fonction : Auteur
  • PersonId : 1068025
Diego Martinez-Plasencia
  • Fonction : Auteur
  • PersonId : 1068026
Sriram Subramanian
  • Fonction : Auteur
  • PersonId : 1068027
We present an approach for the semi-automatic generation of gesture mappings for devices with low gestural resolution such as the Myo Armband, an off-the-shelf EMG capture device. As an exemplar interactive task, we use text-entry: a pervasive and highly complex interaction. We quantify data related to interaction combining systematic studies (i.e., error, speed, accuracy) and semi-structured workshops with experts (e.g., cognitive load, heuristics). We then formalize these factors in a mathematical model and use optimization algorithms (i.e. simulated annealing) to find an optimum gesture mapping. We demonstrated our method in a text-entry application (i.e., complex interactive dialogue) comparing our approach with other computationally determined mappings using naive cost functions. Our results showed that the designers mapping (with all factors weighted by designers) presented a good balance on performance in all factors involved (speed, accuracy, comfort, memorability, etc.), consistently performing better than purely computational mappings. The results indicate that our hybrid approach can yield better results than either pure user-driven methodologies or pure data-driven approaches, for our application context featuring a large solution space and complex high-level factors.
486811_1_En_38_Chapter.pdf (1.05 Mo) Télécharger le fichier
hal-02544535 , version 1 (16-04-2020)
Paternité
Roberto Montano-Murillo, Teng Han, Pourang Irani, Diego Martinez-Plasencia, Sriram Subramanian. Designer Led Computational Approach to Generate Mappings for Devices with Low Gestural Resolution. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.623-643, ⟨10.1007/978-3-030-29381-9_38⟩. ⟨hal-02544535⟩
17 Consultations
24 Téléchargements
