Analyzing Accessibility Barriers Using Cost-Benefit Analysis to Design Reliable Navigation Services for Wheelchair Users
This paper explores ‘A to B’ routing tools designed to chart accessible routes for wheelchair users. We develop and present a novel measurement framework based upon cost-benefit analysis in order to evaluate the real-world utility of routing systems for wheelchair users. Using this framework, we compare proposed routes generated by accessibility tools with the pedestrian routes generated by Google Maps by means of conducting expert assessments of the situation on the ground. Relative to tools aimed at pedestrians, we find that these tools are not significantly more likely to produce an accessible route, and more often than not, they present longer routes that arise from imaginary barriers that do not exist in the real world. This analysis indicates how future routing tools for wheelchair users should be designed to ensure that they genuinely ameliorate the effects of accessibility barriers in the built environment.
Informatique [cs]
