Optimal Time and Space Leader Election in Population Protocols
Population protocols are a model of distributed computing, where $n$ agents with limited computational power and memory perform randomly scheduled pairwise interactions.
A fundamental problem in this setting is that of leader election, where all agents start from the same state, and they seek to reach and maintain a global state where exactly one agent is in a dedicated leader state.
A significant amount of work has been devoted to the study of the time and space complexity of this problem.
Alistarh et al.~(SODA'17) have shown that $\Omega(\log\log n)$ states per agent are needed in order to elect a leader in fewer than $\tilde\Theta(n^2)$ expected interactions.
Moreover, $\Omega(n\log n)$ expected interactions are required regardless of the number of states (Sudo and Masuzawa; 2020).
On the upper bound side, Gasieniec and Stachowiak (SODA'18) have presented the first protocol that uses an optimal, $\Theta(\log\log n)$, number or states and elects a leader in $O(n \log^2 n)$ expected interactions.
This running time was subsequently improved to $O(n \log n\log\log n)$ (Gasieniec et al.; SPAA'19).
In this paper we provide the first leader election population protocol that is both time and space optimal:
it uses $\Theta(\log\log n)$ states per agent, and elects a leader in $O(n\log n)$ interactions in expectation.
A key novel component of our approach is a simple protocol that efficiently selects a small set of agents of poly$(\log n)$ size, given an initial set of $s = O(n^\epsilon)$ selected agents.
Unlike existing approaches, which proceed by shrinking the initial set monotonically over time, our novel component first increases the set in a controlled way to a specific size (which is independent of $s$) before it shrinks the set to a poly$(\log n)$ size.
Informatique [cs]
