Strong and weak constraint variational assimilations for reduced order fluid flow modeling, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00772297
, J. Comput. Phys, vol.231, issue.8, pp.3264-3288
, Numerical Weather Map Analysis. Tellus, vol.7, issue.3, pp.329-340, 1955.
Representing model error in ensemble data assimilation, Nonlinear Processes in Geo-790 physics, vol.21, pp.971-985, 2014. ,
Model error and sequential data assimilation: A deterministic formulation, Quarterly Journal of the Royal Meteorological Society, vol.134, issue.634, pp.1297-1313, 2008. ,
Turbulent complex flows reconstruction via data 795 assimilation in large eddy models, 2018. ,
, Deciphering the role of small-scale inhomogeneity on flow structuration: a stochastic approach
URL : https://hal.archives-ouvertes.fr/hal-02398521
Fast 3d flow reconstructions from 2d cross-plane observations, Experiments in Fluids, vol.60, p.30, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02012453
Coarse large-eddy simulations in a transitional wake flow with flow models under location 805 uncertainty, Comput. Fluids, vol.168, pp.170-189, 2018. ,
Large scale flows under location uncertainty: a consistent stochastic framework, Q. J. R. Meteorolog. Soc, vol.144, issue.710, pp.251-260, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01629898
An operational objective analysis system. Mon. 810 Weather Rev, vol.87, pp.367-374, 1959. ,
Variational assimilation of POD low-order dynamical systems, J. Turbul, vol.8, p.9, 2007. ,
Tomographic particle image velocimetry, Exp. Fluids, vol.41, issue.6, pp.933-947, 2006. ,
Sequential data assimilation with a nonlinear quasigeostrophic model using Monte Carlo methods to forecast error statistics, 1994. ,
, J. Geophys. Res. Oceans, vol.99, issue.C5, pp.10143-10162
The ensemble Kalman filter for combined state and parameter estimation, IEEE Control Systems, vol.29, issue.3, 2009. ,
Sliding window procedure for super near real-time continuous GPS water vapor estimation using predicted orbits, Annales Geophysicae, vol.16, 1998. ,
, GPS Meteorology: Sliding-Window Analysis*, vol.22, pp.825-687, 2005.
A dataassimilation method for Reynolds-averaged Navier-Stokes-driven mean flow reconstruction, J. Fluid Mech, vol.759, pp.404-431, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01117094
A DNS study of jet control 830 with microjets using an immersed boundary method, Int. J. Comput. Fluid Dyn, vol.28, issue.6-10, pp.393-410, 2014. ,
Novel approach to nonlinear/non-Gaussian Bayesian state estimation, IEE Proceedings F -Radar and Signal Processing, vol.140, issue.2, p.107, 1993. ,
Inflow and initial conditions for direct numerical simulation based on adjoint data assimilation, J. Comput. Phys, vol.242, pp.480-497, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00654290
Model error in data assimilation, Nonlinear and Stochastic Climate Dynamics, 2017. ,
TAPENADE 2.1 user's guide, 2004. ,
Stochastic representation of the Reynolds transport theorem: revisiting large-scale modeling, Comput. Fluids, vol.156, pp.456-469, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01394780
, A High-Order, vol.845, 2010.
, Algorithm for Adjoint-Based Optimization for Aeroacoustics Control, 16th AIAA/CEAS Aeroacoustics Conference. American Institute of Aeronautics and Astronautics
High-order compact schemes for incompressible flows: A simple and efficient method with quasi-spectral accuracy, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00459942
, J. Comput. Phys, vol.228, issue.16, pp.5989-6015
Variational algorithms for analysis and assimilation of meteorological observations: theoretical aspects, Tellus A, vol.38, issue.2, pp.97-110, 1986. ,
Optimal control of systems governed by partial differential 855 equations problèmes aux limites, p.407, 1971. ,
A reduced order model based on Kalman filtering for sequential data assimilation of turbulent flows, J. Comput. Phys, vol.347, pp.207-234, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01593854
Fluid flow dynamics under location uncertainty, Geophys, vol.860, 2014. ,
, Astro. Fluid, vol.108, issue.2, pp.119-146
Reconstruction of unsteady viscous flows using data assimilation schemes, J. Comput. Phys, vol.316, pp.255-280, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01333881
Optimal sensor place-865 ment for variational data assimilation of unsteady flows past a rotationally oscillating cylinder, Journal of Fluid Mechanics, vol.823, pp.230-277, 2017. ,
Updating quasi-Newton matrices with limited storage, Math. Comput, vol.35, issue.151, pp.773-782, 1980. ,
Data assimi-870 lation with the weighted ensemble Kalman filter, Tellus A, vol.62, issue.5, pp.673-697, 2010. ,
Experimental and numerical studies of the flow over a circular cylinder at Reynolds number 3900, Phys. Fluids, vol.20, issue.8, p.85101, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00383669
Geophysical flows under lo-875 cation uncertainty, Part I Random transport and general models, Geophys. Astro. Fluid, vol.111, issue.3, pp.149-176, 2017. ,
Geophysical flows under location uncertainty, Part II Quasi-geostrophy and efficient ensemble spreading, Geophys. Astro. Fluid, vol.111, issue.3, pp.177-208, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01391476
Geophysical flows under location uncertainty, Part III SQG and frontal dynamics under strong turbulence conditions, Geophys. Astro. Fluid, vol.111, issue.3, pp.209-227, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01391484
An Objective Analysis Based on the Variational Method, J. Meteorolog. Soc. Jpn. Ser. II, vol.36, issue.3, pp.77-88, 1958. ,
Some basic formalisms in numerical variational analysis, 1970. ,
, Mon. Weather Rev, vol.98, issue.12, pp.875-883
Instability waves in a low-Reynolds-number planar jet investigated with hybrid simulation combining particle tracking velocimetry and direct numerical simulation, Journal of 890 Fluid Mechanics, vol.655, pp.344-379, 2010. ,
Model reduction using dynamic mode decomposition, C. R. Mécanique, vol.342, issue.6-7, pp.410-416, 2014. ,
High-resolution data assimilation through stochastic subgrid tensor and parameter estimation from 4denvar, Tellus 895 A, vol.69, pp.1-24, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01500140
Enhanced ensemblebased 4dvar scheme for data assimilation, Comput. Fluids, vol.115, pp.201-210, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01144923
