Preface to the Special Section Issue on Improving Software Quality through Formal Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Software Quality Journal Année : 2020
This special issue is dedicated to the presentation of novel results in the scope of formal methods for the verification and testing of software. The papers included in the special issue showcase approaches that successfully combine a rigorous and formal background with the capability to address real software applications in realistic settings.
sqj-editorial-author.pdf (79.95 Ko) Télécharger le fichier
hal-02548907 , version 1 (21-04-2020)
Yliès Falcone, Leonardo Mariani. Preface to the Special Section Issue on Improving Software Quality through Formal Methods. Software Quality Journal, 2020, pp.1-2. ⟨10.1007/s11219-020-09508-z⟩. ⟨hal-02548907⟩
72 Consultations
98 Téléchargements
