Boosting methods for regression, Machine Learning, vol.47, pp.153-200, 2002. ,
Boosting with the L 2 loss: regression and classification, J. Amer. Statist. Assoc, vol.98, issue.462, pp.324-339, 2003. ,
Neural network learning: theoretical foundations, 1999. ,
Deep learning, 2016. ,
On the relation between the sharpest directions of DNN loss and the SGD step length, 2018. ,
Learning overparameterized neural networks via stochastic gradient descent on structured data, Advances in Neural Information Processing Systems, pp.8157-8166, 2018. ,
A distribution-free theory of nonparametric regression, Springer Series in Statistics, 2002. ,
Introduction to nonparametric estimation, Springer Series in Statistics, 2009. ,
Mathematical foundations of infinitedimensional statistical models, 2016. ,
Theory of reproducing kernels, Transactions of the American mathematical society, vol.68, issue.3, pp.337-404, 1950. ,
A training algorithm for optimal margin classifiers, Proceedings of the Fifth Annual Workshop on Computational Learning Theory, COLT '92, pp.144-152, 1992. ,
On the mathematical foundations of learning, Bull. Amer. Math. Soc. (N.S.), vol.39, issue.1, pp.1-49, 2002. ,
Support vector machines. Information Science and Statistics, 2008. ,
Optimal rates for the regularized leastsquares algorithm, Found. Comput. Math, vol.7, issue.3, pp.331-368, 2007. ,
Neural tangent kernel: Convergence and generalization in neural networks, Advances in neural information processing systems, pp.8571-8580, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01824549
Learning with Kernels: Support Vector Machines, Regularization, Optimization, and Beyond, 2001. ,
Kernel Methods for Pattern Analysis, 2004. ,
On regularization algorithms in learning theory, J. Complexity, vol.23, issue.1, pp.52-72, 2007. ,
Optimal rates for regularization of statistical inverse learning problems, Found. Comput. Math, vol.18, issue.4, pp.971-1013, 2018. ,
Optimal rates for spectral algorithms with least-squares regression over Hilbert spaces, Appl. Comput. Harmon. Anal, vol.48, issue.3, pp.868-890, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-01958890
Early stopping and non-parametric regression: an optimal data-dependent stopping rule, J. Mach. Learn. Res, vol.15, pp.335-366, 2014. ,
Weak convergence and empirical processes, 1996. ,
Convex optimization, 2004. ,
Adaptive kernel methods using the balancing principle, Found. Comput. Math, vol.10, issue.4, pp.455-479, 2010. ,
Lepskii principle in supervised learning, 2019. ,
Early stopping-but when?, Neural Networks: Tricks of the trade, pp.55-69, 1998. ,
Boosting with early stopping: Convergence and consistency, Ann. Statist, vol.33, issue.4, pp.1538-1579, 2005. ,
On early stopping in gradient descent learning, Constr. Approx, vol.26, issue.2, pp.289-315, 2007. ,
Early stopping for kernel boosting algorithms: a general analysis with localized complexities, IEEE Trans. Inform. Theory, vol.65, issue.10, pp.6685-6703, 2019. ,
Early stopping for statistical inverse problems via truncated SVD estimation, Electron. J. Stat, vol.12, issue.2, pp.3204-3231, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01966326
Optimal adaptation for early stopping in statistical inverse problems, SIAM/ASA J. Uncertain. Quantif, vol.6, issue.3, pp.1043-1075, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01426253
High-dimensional probability, 2018. ,
Learning from examples as an inverse problem, J. Mach. Learn. Res, vol.6, pp.883-904, 2005. ,
Regularization theory for ill-posed problems, 2013. ,
Learning theory estimates via integral operators and their approximations, Constr. Approx, vol.26, issue.2, pp.153-172, 2007. ,
Effective dimension and generalization of kernel learning, Advances in Neural Information Processing Systems, pp.471-478, 2003. ,
Shannon sampling. II. Connections to learning theory, Appl. Comput. Harmon. Anal, vol.19, issue.3, pp.285-302, 2005. ,
Convergence rates of kernel conjugate gradient for random design regression, Anal. Appl. (Singap.), vol.14, issue.6, pp.763-794, 2016. ,
Statistical optimality of stochastic gradient descent on hard learning problems through multiple passes, Advances in Neural Information Processing Systems, pp.8114-8124, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01799116
Sobolev norm learning rates for regularized least-squares algorithms, 2019. ,
The goldenshluger-lepski method for constrained least-squares estimators over rkhss, 2018. ,
Non-asymptotic adaptive prediction in functional linear models, J. Multivariate Anal, vol.143, pp.208-232, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01817385
Regularization of inverse problems, 1996. ,
Discrepancy principle for statistical inverse problems with application to conjugate gradient iteration. Inverse Problems, vol.28, p.23, 2012. ,
Benign overfitting in linear regression, 2019. ,
Smoothed residual stopping for statistical inverse problems via truncated SVD estimation, 2019. ,
, Local Rademacher complexities. Ann. Statist, vol.33, issue.4, pp.1497-1537, 2005.
Local Rademacher complexities and oracle inequalities in risk minimization, Ann. Statist, vol.34, issue.6, pp.2593-2656, 2006. ,
Oracle inequalities in empirical risk minimization and sparse recovery problems, Lecture Notes in Mathematics, vol.2033, 2011. ,
An introduction to matrix concentration inequalities, 2015. ,
On some extensions of Bernstein's inequality for selfadjoint operators, Statist. Probab. Lett, vol.127, pp.111-119, 2017. ,
Kernel ridge vs. principal component regression: minimax bounds and the qualification of regularization operators, Electron. J. Stat, vol.11, issue.1, pp.1022-1047, 2017. ,
A nonasymptotic theory of independence, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00794821
Optimal rates for regularization operators in learning theory, 2006. ,
Matrix analysis, 1997. ,
High-probability bounds for the reconstruction error of PCA, Statist. Probab. Lett, vol.161, p.108741, 2020. ,
