Abstract : TBFMM, for task-based FMM, is a high-performance package that implements the parallel fast multipole method (FMM) in modern C++17. It implements parallel strategies for multicore architectures, i.e. to run on a single computing node. TBFMM was designed to be easily customized thanks to C++ templates and fine control of the C++ classes inter-dependencies. Users can implement new FMM kernels, new types of interacting elements or even new parallelization strategies. As such, it can effectively be used as a simulation toolbox for scientists in physics or applied mathematics. It enables users to perform simulations while delegating the data structure, the algorithm and the parallelization to the library. Besides, TBFMM can also provide an interesting use case for the HPC research community regarding parallelization, optimization and scheduling of applications handling irregular data structures.
