Evidence Humans Provide When Explaining Data-Labeling Decisions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Judah Newman
  • Fonction : Auteur
  • PersonId : 1068624
Bowen Wang
  • Fonction : Auteur
  • PersonId : 1068625
Valerie Zhao
  • Fonction : Auteur
  • PersonId : 1068626
Amy Zeng
  • Fonction : Auteur
  • PersonId : 1068627
Michael L. Littman
  • Fonction : Auteur
  • PersonId : 1068628
Blase Ur
  • Fonction : Auteur
  • PersonId : 1068629
Because machine learning would benefit from reduced data requirements, some prior work has proposed using humans not just to label data, but also to explain those labels. To characterize the evidence humans might want to provide, we conducted a user study and a data experiment. In the user study, 75 participants provided classification labels for 20 photos, justifying those labels with free-text explanations. Explanations frequently referenced concepts (objects and attributes) in the image, yet 26% of explanations invoked concepts not in the image. Boolean logic was common in implicit form, but was rarely explicit. In a follow-up experiment on the Visual Genome dataset, we found that some concepts could be partially defined through their relationship to frequently co-occurring concepts, rather than only through labeling.
488593_1_En_22_Chapter.pdf (3.15 Mo) Télécharger le fichier
hal-02553853 , version 1 (24-04-2020)
Paternité
Judah Newman, Bowen Wang, Valerie Zhao, Amy Zeng, Michael L. Littman, et al.. Evidence Humans Provide When Explaining Data-Labeling Decisions. 17th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2019, Paphos, Cyprus. pp.390-409, ⟨10.1007/978-3-030-29387-1_22⟩. ⟨hal-02553853⟩
34 Consultations
24 Téléchargements
