MOZART: Design and Deployment of Advanced IoT Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Internet of Things (IoT) aims at sensing and altering our surrounding environment through connected objects to improve everyday life. IoT applications are built using interconnected objects with a goal to provide added-value services. However, there are still challenges in providing a secure, robust and easy-to-use end-user platform for development of such applications. In this paper, we present a end-user tool for supporting the design and deployment of smart home IoT applications. The tool first provides a graphical user interface to specify an IoT application using a rule-based composition language. Automated analysis techniques can then be called for verifying that the designed application is correct (e.g., free of deadlocks). Finally, the tool provides a rule execution engine to support application deployment. The tool is built by implementing a set of components on top of Mozilla WebThings platform, which is a concrete implementation of W3C's Web of Things specification.
main-web-preprint.pdf (724.9 Ko) Télécharger le fichier
hal-02554029 , version 1 (24-04-2020)
Ajay Krishna, Michel Le Pallec, Alejandro Martinez, Radu Mateescu, Gwen Salaün. MOZART: Design and Deployment of Advanced IoT Applications. WWW 2020 - International World Wide Web Conference, Apr 2020, Taipei, Taiwan. pp.1-4, ⟨10.1145/3366424.3383532⟩. ⟨hal-02554029⟩
321 Consultations
280 Téléchargements
